0 Mikuni hsr42
0 Clutch Went Out of Adjustment
0 Where do they go?
0 what size motor?
0 120/80/16 rear tire anyone?
0 Front Turn Signals: Where do they plug into?
0 FTC - Harley-Davidson - Customers’ Right to Repair
0 Massachusetts 2022
Last Post: skien
0 Swingarm pivot parts
Last Post: Kit352
0 Messing with Methanol
0 external adjustable float for dc12
0 Mikuni VM38-9 ?
Last Post: Doc308
0 Not Running Right
Last Post: Mr Dream Merchant
0 ^ Baker Speed Kit For Sportsters? Other Solutions
0 West Virginia fall run 2022
Last Post: joes95bobber
0 Happy Birthday Stairman!!!
Last Post: clif02
0 Seeking information on long lost "race" parts
8 Fire Door taking all my bike money
Last Post: Pop Alexandr
0 1983 XLX Rear Mag Bearing Parts order
Last Post: mgentry66
0 Wtf???
Uquackmeup (70), Ralphthe3rd (64), BigJim (62), DollarBil (61), DM-SC (59), nickstoyz (57), HD CRAZY (55), Roadkill (52), Ekalb2000 (50), someday808 (46), bob.cremeans (44)
Old 27th November 2021
Congojack Congojack is offline
Sportster/Buell Model: Ironhead XLCH
Sportster/Buell Year: 1976
Congojack is an unknown quantity at this point
Originally Posted by jeffro57 View Post
crap in your fuel system, start with your tank, lines ,filter then your carb again
I did notice there is some stuff in the tank, but fuel is flowing through lines to carb
Racepres Racepres is offline
Racepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud ofRacepres has much to be proud of
Originally Posted by Congojack View Post
I believe so, fuel seems to be flowing to the carb, there’s a good amount of fuel in the in line filter
I would Not run an inline filter... Gonna give Problems...
was it there before you began having problems???
As already said... What did you do to the bike just prior to developing problem??
It was there before the problems, I had just gotten the bike back from a shop after 8 months when I started noticing the problems. That’s when I rebuilt the carb, few days after the rebuild is when the problems came back. Even after the rebuild though it was running kinda weird. Felt sluggish when I would stop and hold the clutch in at 1st. What would you recommend instead of a in line filter?
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
My suggestion would be to research on this forum how to adjust your pushrods and how to properly inspect , adjust and set your point ignition timing (BPI needs proper battery voltage to operate, don’t forget that portion).
Research and read until you are 100% confident in understanding and how to execute both of these procedures. They are bar none two of the mandatory task that an Ironhead owner absolutely needs to understand.
After you certainly know those two items, start reading on the importance of zero manifold leaks.
Then you can tune your carb.
Just my suggestion.
…Even after the rebuild though it was running kinda weird. Felt sluggish when I would stop and hold the clutch in at 1st.
Do you mean it’s trying to lurch forward in 1st when stopped? That would likely be a clutch adjustment issue.
No, like it wanted to shut off, I would keep having to hit the throttle. Then it would most likely shut off when trying to take off.
Just my suggestion.
Thanks I appreciate it, I saw a video on YT, I think it’s by lowbrow customs, where they showed how to adjust the pushrods and set the points. I’m gonna have to watch and rewatch that then check all that stuff.
But still, if this is happening in gear your clutch could be dragging a bit. It’s life with a “wet” clutch. There’s a fine line between adjusted just right and dragging. If it doesn’t act like it wants to die in neutral but does in gear, revisit your clutch adjustment. What weight oil is in your primary?
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
OK. What did the shop do to the bike in 8 months ?
You need to learn to do things systematically. Just guessing and doing things randomly is not a great idea. You may "play" with things you don't need to and possibly cause further problems.
I always begin with a compression test. Compression gauges are cheap and not hard to use.
They will tell you a lot about your engine.
Your obviously familiar with taking the carb off so substitution will save a lot of time and effort when it comes to carb problems. $49 on ePray will get you a new fake S&S Super E jetted for your engine. A cheap tool.
Before you put a new carb on though you do need to make sure your tank, tap and lines are clean. If the tank is rusty inside take the time to do the molasses trick.
After this if the problem is still there it's going to be ignition.
Old 28th November 2021
rocketnorton's Avatar
rocketnorton rocketnorton is offline
Sportster/Buell Year: 1972
Other Motorcycle Model: homebilt fxr
Other Motorcycle Year: 80+
rocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant future
what is the "molasses trick"?
never heard of that one
pete
