0 Coil suggestions please!!!
0 Starter Worked, Then It Didn't
Last Post: VintageVinny
0 Home Brewing
0 This place still sucks!!!
0 V.o.e.s
0 05 sportster custom and bassani road rage
0 2009 Iron 883 Wont Start!
0 Rear sprockets
Last Post: 85IRONDIRT
0 Crank position sensor problems ??
0 07 883 Low .... lifting
0 Pictures of Evos that look Like Ironheads
Last Post: hotrodbiker
0 Rear shocks ?
Last Post: wachuko
Last Post: WKNDZ
Last Post: SLW210
0 Speedo fog
0 Oil pressure switch testing
Last Post: Mission1
0 Best seat for long rides
0 Slip on alternative
kav2ivan (61), Hunt (54), bikerjim67 (54), twenty2 (42), slimstyle05 (41), PatrickSwayz (35), Mwaggoner
Old 11th June 2013
steelworker's Avatar
Other Motorcycle Year: 2016
I use an R clip instead of a split pin.
I doubt there would be space to fit the pin upside-down - the primary case would be in the way.
Clean and grease the bushes frequently.
Replace the spring and bushes when the stand starts to flop about and not stay tight against the bump stop. The spring may look ok, but they do take a set. All the time the bike is on the side stand, the spring is stretched. One of by mates suggested I buy a wheel stand like he has for his Buell, where you can just push the bike in upright so it's not leaning on the stand. I may try that - it'll give me more room in the garage as well as possibly prolonging side stand spring life.
Old 13th June 2013
BlackBikeDave's Avatar
BlackBikeDave BlackBikeDave is offline
BlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant future
Like to see what that looks like. Post some pics please if you do it.
Old 13th June 2013
SpartanDen's Avatar
SpartanDen SpartanDen is offline
SpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond repute
Went to home depot and found an odd looking pin....can't find what it's called, but it should last longer than cotter pin. Also carry a couple of hair pin in my tool kit. Check out the pin fasteners at home spot, loses, menards
Denny
Old 13th June 2013
SpartanDen's Avatar
It's. Called a locking R pin. Goofy looking but it is stainless steel and should outlast a soft steel cotter pin.
Old 13th June 2013
My mate has one like this, which is very stable. Other designs are available. I might even make my own.
http://www.busters-accessories.co.uk...kw=wheel+stand
http://www.workshopping.co.uk/produc...el-chock/FPS7/
Old 20th June 2013
Matty's Avatar
Matty Matty is offline
Psycho Garage Proprietor
Matty has a reputation beyond reputeMatty has a reputation beyond reputeMatty has a reputation beyond reputeMatty has a reputation beyond reputeMatty has a reputation beyond reputeMatty has a reputation beyond reputeMatty has a reputation beyond reputeMatty has a reputation beyond reputeMatty has a reputation beyond reputeMatty has a reputation beyond reputeMatty has a reputation beyond repute
I've had a couple of recent instances where the stand goes up behind the rubber stop. I had a look see after seeing this post and it won't be long before I'm in the same situation if I don't do something about it.
I took some quick measurements and came up with the following parts from McMaster.com
9440T16 - Graphite SAE 841 Bronze Flange Bearing for 3/8" Shaft Diameter, 1/2" OD, 1/4" Length - $1.15 each
92390A283 - 18-8 Stainless Steel Clevis Pin, 3/8" Dia, 2-3/4" Length, 2-1/2" Usable Length - $2.75 each
92418A529 - Bow Tie Cotter Pin, 410 Ss, 5/16"-3/8" Pin Dia, 3/32" Wire Dia - $10.11 10 pack
I ordered 6 of the bearings so I don't have to pay for shipping the next couple times. I went for the bow tie cotter pins just because they're easier. The bonus is I'll have a lifetime supply. lol
I'll let you know if it works or if I blew it.
Matty
Old 20th June 2013
ParrotHead's Avatar
Other Motorcycle Year: 1974
I have only replaced my spring once on my 06 Sporty, and that was because I caught it on a ramp and bent it. Bushings I service according to the manual and after 93,000 miles (about 150,000 KM) I have had to replace them maybe 3 times.
John Wayne - "The Shootist"
Click here
to listen to my interview on the Chasing the Horizon Podcast
Old 21st June 2013
Matty...looks like you had better change that soon. Ya don't want that falling off when you are riding and hit a pot hole. Don't forget to grease that good and check it everytime you do your oil.
Old 21st June 2013
Matty's Avatar
I'm learning from your misfortune Dave. The parts will arrive Monday. I got graphite bearings so I don't have to grease them. I'll have two spare sets so it will become part of my maintenance program. I guess 39K miles to too long a haul for these parts. Thanks for the original post. Without it I would have been blissfully ignorant until the day I went to put the missing jiffy stand down.
Old 21st June 2013
luvmysprty's Avatar
luvmysprty luvmysprty is offline
Sportster/Buell Model: xl 1200
Sportster/Buell Model #2: 883
luvmysprty is a name known to allluvmysprty is a name known to allluvmysprty is a name known to allluvmysprty is a name known to allluvmysprty is a name known to allluvmysprty is a name known to allluvmysprty is a name known to allluvmysprty is a name known to allluvmysprty is a name known to allluvmysprty is a name known to allluvmysprty is a name known to all
Had a similar problem on Wednesday. Rode to work, went to put the stand down and it fell off. Somehow I still had the stand, spring and bottom bushing. Didn't think it was a big deal. Had a co-worker hold the bike up while I put the stand and pin in to hold it for the day. Got off, took the bike home and put it on the jack while I ran to the dealership for new bushings. $14 for 2 bushings! Got it put back together and all is good. The only problem I had was yesterday. I work at a tobacco free facility and I have a disgusting smoking habit. Jump on the bike at lunch and cruise up to the truck stop a couple bocks away to park in the shade and have a smoke. The edge of the parking lot has a very slight incline. I put the stand down and lean the bike over, it gets to where it normally stops and keeps leaning a little further. I'm such a genius that instead of realizing I'm on a little incline and it's going to lean a little further I panic thinking the new cotter pin broke and I'm dropping my bike. I stand up straight brace myself for the full weight of the bike going over and yank it upright. Everything would have been ok if I didn't slam the tank directly into my nuts! Spent my smoke break feeling like an idiot with a throbbing crotch. Just one more reason I should quit smoking.
