0 Pub/shop mirror
Last Post: bill smith
0 Locked up '72
0 2025 XL Forum Calender
0 Belt tension
Last Post: bplinson
0 C.O.B.B. Spring 2024
0 Brand New '78 Sportster
Last Post: Diamond Dave
0 65 xlch
0 Major update forthcoming
Last Post: bplinson
0 Happy Hanukah
3 Ironhead Pictures Thread
Last Post: Kombi1966
0 1970-71 cylinders
0 Ironhead Exhaust Poll
0 Mosey, where you at?
Last Post: MDT
0 Cylinder Date Codes
Old 31st May 2023
Napawineguy Napawineguy is offline
Location: Isnt this the same as what city, or do you want my actual address.
Napawineguy is an unknown quantity at this point
Default Broke off chuck of the case
I have a 05 1200 custom, want to see if anyone else has had this problem, because im trying to figure out a good way to solve it. So what happened is a chunk of the case broke off, its the top half of the area that the starter bolts to. Right through the center of the bolt holes. So i took it down and got it tig welded, but because its through the center of those bolt holes, when i bolted the starter back on it started to sepperate it again there. Looking for anyone who might have had the same problem and how they fixed it, if they fixed it. I would hate to think my motor is trashed now because of this.
Old 1st June 2023
rocketnorton's Avatar
rocketnorton rocketnorton is offline
Sportster/Buell Year: 1972
Other Motorcycle Model: homebilt fxr
Other Motorcycle Year: 80+
rocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant future
bad weld job
holes shoulda been opened up to resemble trough, then filled in solid, redrilled n tapped
ideally welding would be on both sides, sometimes not possible tho
pete
Old 1st June 2023
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Originally Posted by Napawineguy View Post
...a chunk of the case broke off, its the top half of the area that the starter bolts to. Right through the center of the bolt holes. So i took it down and got it tig welded, but because its through the center of those bolt holes, when i bolted the starter back on it started to sepperate it again there...
If you want (good) advice we need a couple pics to see what you're dealing with.
Old 1st June 2023
I will take some pics of it. I dont think it was a bad weld job, this is a good shop been around a long time here, think he just did the best he could with what he was working with. Like i said ill go out now and take some pics, its just a bad spot for a brake, and hard to get into that area to weld. I just lookes and it looks like its not to hard of a job to install a kickstarter kit. Avout the only thing i havent done yet is pull my trani out and do any work on it, but i girss a good time to learn. Not sure what the cost of the kit is though.
Old 1st June 2023
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
How did it break?
John
Old 15th June 2023
Ive been trying to attatch pics, but for some reason this site has made that no easy task. Im not a 100% on how it happened. Just one day noticed a crack on the top part, so put so jb weld on, and had no problem for a long time, but changing out starters finished the break, and if i had to guess it would be that thats what started it. Im thinking im gonna have to save up and put a kick start kit on, but seeing how i just took a huge hit on my income, thats going to be a little bit. Im sure i can do the work myself, and then i can just have that piece tig welded and the holes sealed, and with no starter there, shouldnt have a problem again. I just dont see how to get any strength back in that areawith welding again. Anyone with a sportster thats yhe same year, or years with the same set up, just picture where your starter attatchesand through the 2 bolt holes right through the center, the top half of that area the starter attaches to is broke off. Thats the best i can describ it since i cant get the pics on, but ill keep trying.
Old 15th June 2023
https://ibb.co/GpTJrLg
Old 15th June 2023
Sorry buy its forcing me to do these 1 at a time https://ibb.co/b1B4NG1
Old 15th June 2023
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
So I can see it
Traveled to
Old 15th June 2023
rokytnji's Avatar
Not sure why it is separating. No bolt holes close by or locating pins.
Maybe have to stud the holes on both sides and over gasket it?
