0 Torque is never enough
Last Post: DrMotorcycle
0 It's been a great Ride!
Last Post: Akdawg
0 Chrome
0 Allegheny 2023
0 Fiber Washer on Idler Gear
0 Electronic ignition or points?
0 Saturday Sportster Season 2
Last Post: PoodlePunche
0 Riding with Diabetes
0 1999 1200S Sport ignition
Last Post: porkchop3583
Last Post: Turbo Sporty 48
0 Running Errands, Long Way Home
Last Post: bagster guy
0 Air Filter
Last Post: br549arkie
0 New budget bar bike build
0 Bad Speedometer or Bad VSS?
0 Loco's Garage Sale
Last Post: LocoLocal
0 stroker pistons found
Last Post: rocketnorton
OKsporty (70), humpbackbob (69), Sunnydazepleaze (61), dvsxtc (58), elmo (46)
caseyjones caseyjones is offline
Sportster/Buell Model: 883
caseyjones has a spectacular aura aboutcaseyjones has a spectacular aura aboutcaseyjones has a spectacular aura aboutcaseyjones has a spectacular aura aboutcaseyjones has a spectacular aura aboutcaseyjones has a spectacular aura aboutcaseyjones has a spectacular aura aboutcaseyjones has a spectacular aura aboutcaseyjones has a spectacular aura about
Default Sumped oil.
My 98 1200 had sumped it's motor oil before l started stripping it down about a year ago, l'm planning to take the motor out using the "lay it on it's side and lift the frame off" method as my back is no good for lifting motors anymore.
My concern is what will happen to the remaining oil in the bottom of the motor?...is there any way of draining it other than cranking the motor?...bike has no electrics fitted at the moment so that would be tricky.
Thanks in advance.
why not use an over head lift. i use a chain foil and short nylon strap. do not worry about the oil. you cannot pump it all out anywho.
JB in NC JB in NC is offline
Sportster/Buell Year #2: 1993
Other Motorcycle Model: H-D FLH
Other Motorcycle Year: 1980
JB in NC has a brilliant futureJB in NC has a brilliant futureJB in NC has a brilliant futureJB in NC has a brilliant futureJB in NC has a brilliant futureJB in NC has a brilliant futureJB in NC has a brilliant futureJB in NC has a brilliant futureJB in NC has a brilliant futureJB in NC has a brilliant futureJB in NC has a brilliant future
Yes, don't worry about the oil. It will drain back down to the sump when you stand the motor back upright. It can't go anywhere in the motor where there is not already oil.
Jim
You could pull the heads and use an extraction pump thru the cylinder holes.
But that still won't remove all of the oil. Be lighter though without heads and sumped oil.
The pump below was cheap at Harbor Freight. Works great.
denguy denguy is offline
denguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond repute
Says a lot. ''It can't go anywhere in the motor where there is not already oil.''
Bluto Bluto is offline
Other Motorcycle Year: 1973
West Marine sells a few good oil extractors, I use the one below on my dry sump bikes and a bigger 6 quart version for cars (extract the oil via the dipstick tube)
Sportster/Buell Year #2: '03
i started doing it that way because it's the procedure described in my factory service manual.
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
How much would the case, and crank weigh, if you removed the cylinders, cams, clutch hub and rotor components? On a rigid, you could also pull the transmission, which probably weighs a lot.
John
Nice Norton. Vacuum pumps work nice. Careful with that nice gas tank. Is that some blue on the nice exhaust pipe?
glutton for punishment
if i was only doing a top end, yep why pull the engine, BUT, if the engine must come out, why work in tight spaces, the bench is wide open.
like changing the cogsworth belts on a dogalac, easier to remove grill, ac condenser and radiator. you can't barely get your hand in the few inches they give you, you literally have to reverse how it was put together.
