0 Cartridge Conversion?
0 Hello from Kentucky
0 Hello from Toronto, Canada!
Last Post: cotton1
Last Post: MXHD55U
0 Tried to buy a new helmet
0 Gaskets & Rubber
Last Post: sltm1
0 Ironheads ain't worth more than $1,500 (1969 XLH original paint)
Last Post: MXHD55U
0 Oil??
0 This Week in my Shop
0 Transmission help!!! tire locks up downshifting!!!
Last Post: Jefferymares
0 Any K model guys interested in cam regrinding?
0 THE Hockey Thread
Last Post: Airbozo
Old 16th July 2012
DK.Haff's Avatar
DK.Haff DK.Haff is offline
Sportster/Buell Model: XL 1200C
DK.Haff is an unknown quantity at this point
Default What 2-1 pipe works with wide band O2 sensors??
hey all. im in the market for a new 2-1 pipe. i currently have the d & d fatcat but i run the thundermax and the rear wideband O2 sensor rubs on my starter a bit. just wondering if any others are running the T max and a 2 into 1, and which pipe has clearance without re-welding the bungs! thanks much
Old 16th July 2012
1250IRON's Avatar
1250IRON 1250IRON is offline
Sportster/Buell Model: Iron
1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light
I have the Lsr 2 into 1 with no rubbing issues.
2009 Iron 1250 Kit Stage 2 Light 883 Heads 497 Cams RB LSR 2 into 1 Thundermax Ecm
Old 16th July 2012
DK.Haff's Avatar
hey iron, thx for the response. im pretty sure i have a PM from you i still need to answer as well how long did the pipe take to get to you and how much was it, if you don't mind telling? im kind of on a time and money crunch and am trying to keep it less than 800 bucks...
Old 16th July 2012
DK.Haff's Avatar
after looking into it...i just ordered the LSR.. i'll post back after i get it
Old 16th July 2012
AustinXL's Avatar
AustinXL AustinXL is offline
Other Motorcycle Model: FXDL
AustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud of
I havent heard many complaints (other than the infamous wait) on the LSR pipes, good luck and keep us posted!
Old 17th July 2012
EL in NH's Avatar
EL in NH EL in NH is offline
Sportster/Buell Model: model 48
Other Motorcycle Model: FLHS
Other Motorcycle Year: 1991
EL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to behold
Default alternatives
You can buy new bungs and have them welded in your current pipes
...I have also heard of heating the existing bung with a torch then install a bolt and every so gently bending the bung in the direction needed..
Peace
Old 17th July 2012
1250IRON's Avatar
You will have a wait on the lsr as they are only made when your order is placed. plus if you get the black ceramic that is done at a different location and i think they wait for a few orders to do all at once. Top quality pipes though. the aluminum gaskets are much better than any exhaust gaskets i have seen. when you put it together make sure to put a little gasket sealer on the slip joint where the pipes fit together. i overlooked that in the instructions and i get a little rusty water drip in cold weather until the bike warms up. in my opinion they are well worth the wait. i'm not sure on the time as i purchased the pipe from Dan at NRHS at the same time i did my motor. i wished i had known you were thinking on this pipe because i think Dan sells the pipe a little cheaper than RB Racing. the pipe went to him and he shipped it to me along with all my motor parts and the heads i sent to have headwork. He sells the thundermax at a good price also!
