0 Adjusting Drive Belt While On A Lift
12 Crankcase breathing?
0 Coil polarity
Last Post: JonesL
0 VIN ERROR on speedo/tach combo
0 Range With EFI 3.3 Gal Tank
Last Post: corndog76
0 oil transfer valve
0 New shocks on and old frame?
0 Chinese S&S carbs
Last Post: PetesPonies
0 What's your road name? How did you get it.
Last Post: Bryan1976
Last Post: bordens
0 "S" model specific Q&A
0 Do you use a bike cover?
Last Post: Vic8028
0 N65C or N65A
0 Sportster Fork Upgrade
Last Post: Redbeard2
Last Post: 45Brit
0 Tires for "Rubber mount XL" poll.
Last Post: SLW210
the brewster (75), irate (74), jomosie (71), Gulfstream (63), LordVngr (60), [loopy] (48), aci2sux (46), doc05 (43), TOMSuperlow (41), Crusin_w00kie (40), DFuller1980 (40), h2oburymatt (38), Ivan Iler (36)
84cj's Avatar
84cj 84cj is offline
84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of84cj has much to be proud of
Default Gauntlet fairing on 99 Sport?
Most of the Gauntlet 1/4 fairings I'm finding say they do not fit a Sportster Sport. Anyone have an idea why not? A modification I can do to make it work?
Thanks.
1999 1200S
c1skout's Avatar
c1skout c1skout is offline
Sportster/Buell Model: sportster 1200c
Other Motorcycle Model: Royal Enfield / BMW
c1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant future
I know some small fairings are made to fit with just a central mounted speedo, not the twin gauges that a sport would have. Might be the reason?
MikeBel's Avatar
MikeBel MikeBel is offline
Other Motorcycle Model: Road King Classic
MikeBel is an unknown quantity at this point
I've got a small flyscreen on my '99 1200S and it covers the gauges just fine. So the only thing I can think of as to why they say the gauntlet-style won't fit is that maybe the fairing won't let you access the front suspension adjustment knobs at the top of the forks. If that's it, who cares b/c once you set it you're probably not going to touch it again.
1999 1200S & 2012 Road King Classic
