0 Parts interchange (Rocker Boxes And Rockers)
0 New handlebar wiring harness 81XLH?
Last Post: owlsplace
0 Gasket goo or not to goo
Last Post: hbsporty
0 Looking for washer part and speedo drive info
Last Post: 72 Ironhead XLH
0 Buying another IH
0 Hello from California
Last Post: Bryan1976
0 Use the WTB, WTT, WTS, WTG section
0 First Startup after rebuild questions
Last Post: springcj1
0 1977 Ironhead big fuel tank options
0 Clutch Spring plate poll
Last Post: b0fh
0 Returning Sportster rider
Last Post: clif02
9 Cracked housing
Last Post: Bruce
0 What’s that sound?
Last Post: mwXL 2006
Last Post: b0fh
0 Handlebar diameter
0 Gasket set recommendations
0 The Official SuperLow Thread... Let's See 'Em!!
Last Post: modular
6 Calling all musicians
Last Post: Eddieblz
Last Post: tomaso
Last Post: jharback
0 Been Sitting For 5-10 years; Starts, But Dies
0 peanut tank on custom
Last Post: Karnevil
0 vibration problem solved - CHECK YOUR FRONT ENGINE MOUNT BOLT!!
0 Just wanted to thank everyone
0 hello from a long time lurker
Last Post: priell3
0 left him stranded
0 TC88a DIY Power adapter ?
  #41
CyclesInc's Avatar
CyclesInc CyclesInc is offline
Sportster/Buell Model: A Few
Sportster/Buell Year: many
CyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud of
Looks like Mainshaft 3rd or Countershaft 2nd. Ouch!
Darkseacret Darkseacret is offline
Sportster/Buell Year: 77
Darkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to all
Is my next step to pull motor and start tearing into clutch/ tranny ?
frogg_nutts frogg_nutts is offline
Sportster/Buell Year: 72
Other Motorcycle Model: XLH
Other Motorcycle Year: 80
frogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to behold
No.
Buy this one.
https://greensboro.craigslist.org/mc...852883026.html
Your cheapest fix is to replace the motor with a used one.
Repairing yours can easily cost as much as the purchase of another bike.
As to the transmission I will not run either of the factory 20 tooth gears as they are grenades as you have found. The way the gears are made leaves very narrow margins accompanied by stress risers adjacent to the margin which facilitates splitting.
Andrews Products makes replacement gears that are billet (stronger) instead of forged and also the stress risers are eliminated by a radiused corner in the pockets.
The (2) 20 tooth gears are
35750-56A countershaft 2nd (17-8241 andrews)
and
35305-56A mainshaft 3rd (17-8244 andrews)
Sportster/Buell Year: 1974
needspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant future
Obviously both the engine and transmission need to come out but not necessarily in that order. Sometimes its easier to loosen the tight nuts with it in the frame and pulling the transmission first makes it all lighter. Pulling one or both heads while in the frame makes it even lighter.
It's up to you.
doodah man's Avatar
Absolutely use your frame as an engine stand. Makes life so much easier.
Flame__'s Avatar
Flame__ Flame__ is offline
Sportster/Buell Year: 1989
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2000
Well chit.
Knees in the breeze.
Gamertag, PS4: Bikerdude__
Old 18 Hours Ago
Talked to the builder of my recent top end job . He may have a motor to swap in need of a rebuild . He wants to cut off my trans and mate a shovel transmission to it . Gonna call back Monday and see what motor options he came up with .
Old 14 Hours Ago
Cutting off the trans is more work and expense than fixing it right.
Just say NO!
