0 Homemade Lithium Battery
Last Post: Andy56
0 Primary / Gearbox Oil
0 Magneto + CV carb = which air cleaner?
0 Ironhead Exhaust Poll
0 top end
Last Post: rivethog
Last Post: BWP 5p
0 Backfiring
Last Post: David Kirkha
0 "S" model specific Q&A
Last Post: Vasiliy
0 Ugh the old girl is fighting back
Last Post: 79Harleydavidson
Last Post: Akdawg
Last Post: Robyart
0 Cam cover differences
Last Post: BigMek
Last Post: AZbiker
0 Hi from Vermont
0 Sportsters No More?
Last Post: AZbiker
0 Keihin Butterfly Carb Float Level
Last Post: XL-Novice
0 What’s your take on Harleys ceo putting down the sportster line
Last Post: Cmd11
0 Rocker lockers
Last Post: Pagey
0 Why Harley-Davidson Owners Don’t Like the Street 500 and 750 Motorcycles
Last Post: Yeshua Johns
0 weight loss thread
Last Post: Marsikus
Slinkee, Bwarnerusa1, smoking man (61), dblkick (55), jkoj (55), Chena1 (52), iron goat (49), Uncle Fester (44), Don1903 (41), sporty93 (35), borada75xlch (33)
Old 4th March 2021
Sportster/Buell Year #2: 2008
Default 1250 or 1275 Pistons and Cylinders
We know it is only 25cc so here it is.
The 1250 set installed has coated heavy flat top pistons for turbo, the unpurchased, uninstalled 1275 kit would have lighter flat top pistons.
Less mass in the pistons combined with the XR crank should spool up pretty quick.
Not going with domed pistons, higher compression, Hammer 570 cams are already in hand.
Was planning on switching the pistons and cylinders over to the Roadster and if the spirit moves, turbo the Roadster.
Just want to ride the 48.
So, only about 3% increase in power with 25cc.
Went online to check, Hammer is the only 1275 provider, done a bunch of business with them over the years, always satisfied.
Might add a new oil pump.
Thoughts?
Old 4th March 2021
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
I vote 1275
Old 4th March 2021
Steve9's Avatar
Steve9 Steve9 is online now
Other Motorcycle Model: FXDC
Just because!
Steve
'03 1250 NHRS stage two Lightning heads, 536, mik 42
'01 Cyclone
'13 FXDC 96" stock
Old 4th March 2021
I think you answered your own question. If you're considering putting a/the turbo on the Roadster, saving the "turbo" 1250 pistons and cylinders for it and getting a 1275 kit for the 48 would seem to be the way to go. Or am I missing something? The 1275 kit also gains you some squish area which is a plus.
Old 7th March 2021
Hellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant future
Go big or go home.
Old 7th March 2021
rocketmangb's Avatar
'07 and up should have the updated oil pump already
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 8th March 2021
Default 35K Miles
Just wondering if I should check it out.
