0 Kickstands
Last Post: c1skout
0 One more TSM question
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 points/condenser
Last Post: Whitewalls
0 Gauntlet fairing on 99 Sport?
Last Post: c1skout
0 What happened to the Wuhan virus?
0 Mid West Meet & Greet
0 Lets See Your Nightster
Last Post: vaquerodiablo
0 My New Daughter "Harley Dee"
Last Post: 03SportyBoy
0 Humiliating- I had to push my bike home
0 Roadster Dampers in Nightster
Last Post: Hornsmith
0 Wiring dual headlight help
Last Post: Sportsnerd
0 883 Highway Speed?
Last Post: Hellbent_4
Last Post: Akdawg
0 A couple more noob questions (Relocating Rear Turn Signals)
0 turning idle mixture screw no effect?
0 A couple more noob questions (Fuel, EFI)
0 June 6th, 2020: Ironhead Rider's Gathering, PA/NJ (Spring 2020 G.B.B)
Last Post: Magneto Sportster
0 low comp pistons spark plugs
cobra47 (73), nardo (61), stevo (56), myrl883 (56), h2ocreeker (54), erreoa (53), abodyjoe (51), MJK (44), bobII (41), motoxxx (35)
2000 883, no spark, no start
Old 25th March 2014
TheDuke247 TheDuke247 is offline
TheDuke247 is an unknown quantity at this point
Question 2000 sportster 883 no start
hello everyone. first time on this forum. i have a 2000 sportster that wont start. i have recently changed my spark plugs, coil, and battery. fuel is running from the tank. im not getting a spark from the plugs. i also recently did a coil relocate and a tank lift. when putting everything back together i accidentally cut the black wire goin to the coil . took everything apart and repaired it. everything worked fine until it happened again. so i assumed it was the wire again so i soldered it but before i could rap it a buddy thought it be funny to tap the bare wire to the body and it blew a fuse . replaced the 15amp fuse but still no go. PLEASE HELP.
