0 Momentary starter switch installation question
Last Post: leon bee
0 Laughing shotgun pipes...Kickstarter hits pipe
Last Post: ericfreeman
0 Lifter / Tappet Please Gimme a Hand
Last Post: nhfdias
0 Un-Modded 2013 Forty-Eight Wobble
0 Need help with ideas..
Last Post: robbie202
0 Short Shots w/mid controls
Last Post: Jake42
0 Problem on a trip
0 Michigan Thumb Run:
0 A couple more noob questions
0 883 Highway Speed?
Last Post: SLW210
Last Post: Turbo Sporty 48
0 Turbo Progress
0 Getting Hammered
0 Turbo Iron 883
Last Post: RamblerAl
0 Proper XLCH
Last Post: XL100
Last Post: SLW210
0 Andrews N4 VS Stock D or W grind cams
Last Post: Ghostdog
0 900cc Pistons
Last Post: Staffords
0 Hello from Canada!
billydale (77), twoqk4you (60), MMILLS69 (46), aaaugie (46), MikeyT (45), chardhin, jjphoto (42), promiscuousman (36)
alarm, fuse, ignition, key fob, no start, relay, tssm, wont start
Old 8th June 2018
gaspasser's Avatar
gaspasser gaspasser is offline
gaspasser is on a distinguished roadgaspasser is on a distinguished road
Default No start, pull fuse and reinsert...starts
OK, so heres my mystery. Bike sat for a month. Went to start it and it was on a battery tender so the battery was fine, and the turn signals wouldnt work and the bike would not start....nothing...no click, nothing. tried pulling fuses etc. discovered if i pull the fuse for the blinkers and reinsert it starts just fine.
Replaced the starter relay.....nothing...no help.
**** also, came out to the garage and discovered my running lights on and the bike was completely turned off.
i also replaced the key fob battery in case it was the security system.
any ideas???
Old 8th June 2018
sportsterdoc's Avatar
To declare the battery "fine", it needs to be tested.
It could be on a tender and have a bad cell...or a failed voltage regulator could be drawing amps.
What is battery voltage:
a. key off?
b. key on?
c. while pressing start button?
Old 8th June 2018
Front running lights are powered by blue lighting circuit.
Front turns are powered by orange/white accessory circuit (horn, turns and brake light).
4 way flashers / hazard lights are actuated by pressing both left and right turn switches at the same time.
If front lights are still on, press both turns and see if they turn off.
Old 8th June 2018
rocketmangb's Avatar
Sounds like the TSSM was active
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 9th June 2018
Thanks, George, I did not give thought to the security system.
Old 9th June 2018
gaspasser's Avatar
ok...the TSSM appears to be working correctly. i changed the battery in the key fob. security system turns on and off as its supposed to. the battery holds a charge but has not been load tested. i changed the starter relay.
***** if i pull the blinker fuse out and reinsert it the bike starts and runs fine.....no issues**********
pressing both turn signals produces nada when the starter circuit is not working.
Old 9th June 2018
gaspasser's Avatar
also....i charged the battery overnight last night and without touching the fuse it would not do a thing. headlights come on, running lights come on. signals wont work and start button produces NOTHING. remove fuse and reinsert...starts fine
Old 9th June 2018
gaspasser's Avatar
so i checked the voltage on the battery and its low. back on the charger to see if it comes back to full charge. but why would the front running lights come on while the bike is completely off????? is that a bad battery symptom??? i've never seen it
Old 9th June 2018
m still leaning for an issue in the security module.
Old 9th June 2018
Since pulling the accessory fuse reboots the speedo/tach, that is a good possibility, as well as a main battery voltage issue. Without requested battery voltages, I have no additional input.
