Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Custom Finishing
Last Post: ronccc
0 points/condenser
0 2004 ICM
Last Post: LLOYD883
0 A couple more noob questions
Last Post: Bikeaholic
0 Lifter / Tappet Please Gimme a Hand
0 Michigan Thumb Run:
0 Craigslist
0 How to long term storage?
Last Post: Turbo Sporty 48
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 A Day in the Life...
0 Laughing shotgun pipes...Kickstarter hits pipe
Last Post: Oldmxdog61u
0 Proper XLCH
0 Momentary starter switch installation question
3 Start System Testing
Last Post: LetsDoIt
0 Short Shots w/mid controls
0 Ok 1200 to 1275 for street performance
0 Power cones
Last Post: Serious Blac
0 Un-Modded 2013 Forty-Eight Wobble
0 Need help with ideas..
Last Post: robbie202
jlede (70), hissatsu (65), Mickey Shane (65), jiffylube (54), TEAMGREEN (49), pirogue1 (45), soupman77 (44), kromroykw (43), O48 (43), dracolich, STEVOMERCKX (35)
Old 31st March 2007
Bay View Buell X1
Guest
Posts: n/a
Default license plate on the swing arm?
Does anyone know someone or place that has a mount system to relocate the license plate to the swing arm? Recently put a slick of carbon fiber uner the seat... Looks hot, but what to do with the plate??
The bike is a 2000 Buell X1
Old 31st March 2007
snowman's Avatar
snowman snowman is offline
Take a look at my avatar or my gallery. I put this one from Kuryakin on mine and love it. It may not be your style but it's clean and well made with LED lighting. Also comes with two size clamps for the swingarm..
http://www.customdynamics.com/harley...late_frame.htm
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Old 2nd May 2007
hrdlyabl hrdlyabl is offline
Sportster/Buell Model: X1
hrdlyabl is an unknown quantity at this point
two 1/4 holes and i was able to mount my X1 plate just under lamp housing on tail support.cost nothing and looks ok after rippin' off all that plastic.coupla small locator holes and my signals mounted right back original location.stock tail lamp is clear on bottom of lense so all's cool.
Old 30th May 2007
earl87gta earl87gta is offline
Sportster/Buell Model: X1 Red Race stripe
earl87gta is an unknown quantity at this point
I did the same thing drilled 2 holes under the tail light and taped it so I could bolt it to it I used 2 stainless allen head bolts. looks way better then a tag hanging off the swing arm.
Old 21st June 2007
bsporty's Avatar
bsporty bsporty is offline
Sportster/Buell Model: 1200 xlc-miss it
Sportster/Buell Year: 00
Other Motorcycle Model: Honda CB750F
Other Motorcycle Year: 78
bsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant futurebsporty has a brilliant future
My BF did this to his...
Brandi
2000 Sportster xlc drag/cafe
It is better for others to think you are a fool, than to open your mouth and remove all doubt.
What does cheese say when it gets its picture taken?
Old 4th May 2015
MoodyBlue's Avatar
MoodyBlue MoodyBlue is offline
Sportster/Buell Model: 2002 M2 Cyclone
Sportster/Buell Model #2: Cyclone M2
Sportster/Buell Year #2: 2002
MoodyBlue is an unknown quantity at this point
Default 2002 M2 Cyclone tail alter
I chopped the plastic (not too radical) and drew up and had lazer cut a new plate holder for my Cyclone.
Now having seen another way of doing it (plate mounted to the hugger) I am back to pondering if it will work for my bike.
Number plate lighting (or lack of) is a big points earner for plod here in OZ.
Looks like I'll add a pic, when I figure out how????
