0 Occasional carb spit back, am I missing something?
Last Post: Serious Blac
0 Have you ever BEEN PAID for sex?
Last Post: Eddieblz
Last Post: 83XLX
0 Single women, how old are you?
Last Post: Francois
0 Clutch assembly question on 77 XLCH
Last Post: porch_hornet
0 Larger gas tank for 1996?
Last Post: Bone
0 Front end swap
4 The no-debate OIL POLL
0 Cold?
0 Sticky Valve fix
0 Compensator nut.
0 The one and Only O-Fish-shall Poser thread.
0 Open relationships, swinging, threesomes, et al...
Last Post: spitfirechopper
0 Bearing questions
0 I guess I'm back
Last Post: broknluck
0 turn key on, no power at battery. key off battery good. help
0 Clutch issues
Last Post: Gibson90kb
0 Basic Welding Equipment
0 Massachusetts rides 2019
Last Post: joes95bobber
Last Post: Kennyv
billib (65), Scar (60), koolblue, Spor-T-1 (56), Choppershed (55), Nemo DeNovo (53), harman35 (51), Wannabee (51), crackermank (49), WORM (43)
owlsplace owlsplace is offline
Sportster/Buell Model: XLH 1000cc
Sportster/Buell Year: 1981
owlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud of
Default Highest mileage logged on IH engine?
Back in the 70s when I was riding a lot in New England I bought a 1975 Yamaha 650 XS off the showroom floor with my separation pay from the military and put about 50,000 miles on it in two years before taking a long break to present time before street riding again. That included a 4,500-mile cross country trip.
The current mileage on the 1981 Sportster XLH is 33,000 after restoring the speedometer function. I'm guessing not very many miles were logged while the odometer was offline.
Just curious about who has the highest mileage logged on their Ironhead?
Sent from my SM-S767VL using Tapatalk
good?
i tore mine down for frame restoration and bird in hand, decided to up the ponies to boot. i had right at 170k miles and still kicking strong. on tear down all the measurement came back serviceable.
i could have reused the crank since my measuring devises showed nil and besides, did not know how it left the factory. i dropped in an S&S crank, y cam and tweaked up the compression ratio.
the jugs had about .006 taper so a .010 over bore cleaned it up. i installed valve seats and stainless valve and iron guides. looking for another 200k miles.
so i cannot say who has more but i am def sure somebody does!!!
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
I did not own this bike from zero, but I did do this...
Speedo Rolls Over
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
What was once old is new again!
Merely dying will not get your name removed from the enemies list!
That was worth setting up. Had to view on a laptop to access the link. Good show, Mick.
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
I own a 61 that as far as I can tell has never been rebuilt other that opened reringing. It smokes a little after a couple hours of riding, but runs fine. These motors are similar to tractor and lawn mower motors in their durability. If maintained well, they can run a long time. I have no idea on the miles as it came sans speedo. I have had it 10 years. Brother in law had it 6.
Ok, now I'm revived
iNSaNeSHaNe's Avatar
Sportster/Buell Year: 1985
I bought my 85 XLS from my dad in 2008 . He bought it new I have no earthly idea how many miles are on it.
The speedo was not working when I got it and showed 80k. My dad said it had turned over once before and speedo hadn't been working in years.
Shortly after getting it I put a new speedo drive and cable on it and rode it 2 more years and after speedo tripped again I put in rings.
I rode it a few more years as daily trans and really racked up the miles, about 60k.
It started smoking bad. The heads were shot and had to bore it.
This is where I installed the Ted pistons which lasted only a few months and killed my entire engine when one decided to disintegrate leaving the wrist-pin bouncing in the cylinder all alone at 60 mph.
. . . . . The start of the " WTF HAPPENED " thread
That is when I went nuitz and decided to make a " Stroker " daily ride, and the rest is history.
IT KILLS EVERYTHING , shakes it apart. I've lost bits and pieces on rides, been 4 tachs and 3 speedos come apart.
So no idea on current mileage, but she still makes me smile every day ..
