Last Post: Adam76
0 Hello from San Clemente, California USA
14 Saying Hello /shwmae
0 stress killer
0 Hello from NY
0 Late Ironhead cases interchangeability
Last Post: Mad Max
0 A thank you
Last Post: Serious Blac
Last Post: J.P.
0 Side stand issues on can bus Sportsters?
0 12" or 14"? (Apehangers)
Last Post: Nrg2brn
0 It's Flame__'s Birthday!
0 Hello from Seattle
0 Forum problems???
0 Kapscomoto fxdxt fairing
0 1970 sporty, hard to crank
Last Post: Bama Lee XLC
0 Front brake lever
0 2-1 Header Pipes
Last Post: Medyo Bastos
0 Help me with the physics of the Bendix float
0 Who's still riding???
Last Post: Sadsack
Last Post: oupa
0 compression problems
Last Post: Sadsack
cobra0478 (75), Han (62), priell3 (58), Byrdman (54), jsta (52), YaeDio (51), doc (45), jfunk (45), lenainrouge (44), JohnDao (40), Razer883 (33), Slapchop68 (25)
  #101
Old 31st May 2018
sml1226 sml1226 is offline
You don't even have to go to a side mount. Sure, the touring bikes, dynas, older/newer sportsters all run that, but I never hear of people blowing the guts out of the one on their sport bikes like these do. They're all like what we're running on the rears. They run them straight, without a 90 degree joint in it, but still, I've got mine mounted on the side for my rearsets, and it's no better than before. I'm sure there's something similar of higher quality out there.
If someone wants to go figure out what bike has something good on it with the same bolt spacing, I'd gladly switch mine out for something without a HD logo on it if it means it works better (especially since you don't see the logo anyway...). I just don't want to go buying up rear masters from random bikes just to figure out something with our bolt spacing.
Old 1st June 2018
Redbeard2's Avatar
Redbeard2 Redbeard2 is offline
Sportster/Buell Model: M2 Cyclone
Other Motorcycle Model: Suzuki GSF1200S Bandit
Other Motorcycle Year: 2002
Redbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud ofRedbeard2 has much to be proud of
Default Replacement Master Cylinder
After a bit of study I found a picture of the 2014 and up Sportster mounting system on Ronnie's microfiche. The 14 and up bikes do have an additional bolt hole on the frame. Welding on an extra stud for your bolt would not be too much trouble, difficult but not impossible. Then you could swap out the earlier master cylinder parts for the '14 and up. However I will probably do my own Rube Goldberg engineering and probably add the extra stud but I'll just make an aluminum adapter plate and mount one of the 96-03 Sportster master cylinders and fab up the linkage. These had a good service record and Harley should never have abandoned them! This is a pic of a Drag Specialties replacement unit which is brand new and still for sale.
Old 5th June 2018
Redbeard2's Avatar
Default Pic of the '14+Up Sportster Rear Footpeg Brackets
Here's a pic of the '14 & up Sportster rear Footpeg brackets. H-D added an extra screw boss. Actually these are Chinese made aluminum knock offs sold on E'bay, not rear deal.[IMG][/IMG]
Old 5th June 2018
Redbeard2's Avatar
Default Pic of the '14+Up Sportster rear master cylinder
Here's a pic of the '14 & up Sportster rear master cylinder.
Old 5th June 2018
Redbeard2's Avatar
Default Master Cylinder Upgrade
I would advise against trying to run this '14 + up master cylinder setup on earlier Sporties without adding the third bolt hardpoint to the frame. It's a simple matter of welding on a 3/8-16NC bushing to the frame. The inboard side of the bushing needs to be contoured to the frame. The EVO Sportsters [86-03] had to have a reinforcing bracket on the outboard of the pulley cover because of breakage problems. I'm sure there's a reason why H-D added the third bolt hole to the frame.
Old 24th September 2018
Redbeard2's Avatar
Default More Study on brake Retrofit
After some more study on the brake retrofit I've decided welding the extra thread boss onto the frame is unnecessary IMO. After studying a microfiche from Ronnie's H-D I saw an adapter bracket for the '14 and up master cylinder. There was not part number for it but after I looked at it I realized it was designed to run the newer '14+ master cylinder without the footpeg bracket. The reason for the third and newer bolt hole was to give the adapter bracket a place to bolt on. So I'm sure that you can run the new master cylinder on the pre 14 bikes with no trouble. Two 3/8-16 bolts [gr. 8] should have more then adequate holding power. That's the way I'm going to run my retrofit setup. If it proves inadequate I'll weld the third stud onto my frame.
Old 25th September 2018
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
Just to confirm, you are adapting the newer master cylinder to a rubber mount correct?
If so I'd be interested in seeing photos as I am tired of replacing my master cylinder once a year
John Wayne - "The Shootist"
Old 27th September 2018
Redbeard2's Avatar
Default Modifying '06 Sporty for '14+ rear master cylinder
Parrothead:Just to confirm, you are adapting the newer master cylinder to a rubber mount correct?
That's the plan. I have the '14+ right footpeg/master cylinder bracket and the master cylinder. I still need the midcontrol push rod, the pushrod pin and it's circlip. I'll need to get new brake line plumbing and a new pressure switch too. I also plan to replace the 06 caliper. I'll probably use a Performance Machine 4 piston caliper. The stock Sportster '14+ caliper is a 2 piston unit. I've got a spare rear caliper bracket which I have to modify to take the PM caliper.
Old 6th October 2018
tvon's Avatar
tvon tvon is offline
tvon has a reputation beyond reputetvon has a reputation beyond reputetvon has a reputation beyond reputetvon has a reputation beyond reputetvon has a reputation beyond reputetvon has a reputation beyond reputetvon has a reputation beyond reputetvon has a reputation beyond reputetvon has a reputation beyond reputetvon has a reputation beyond reputetvon has a reputation beyond repute
Jumping in here.. I have an 05 1200R and just shy of the 30k mark. Recently my rears have been kind of weaker than usual. I push down far on the brake to even get it to stop. Today i leave the house and the pedal goes all the way down and little to no brake. I get home and check the pads and the fluid.. all look good. I bled the brake (which took forever.. i'm not new to bleeding the brakes). Still no resistance at all, and i'm positive there is no air in the fluid. Do you think this is the master cylinder needing a rebuild? thanks for your comments.
wedge's Avatar
wedge wedge is offline
Yes
