0 If you could only have one bike, would it be a Sporster?
0 AOL Blows
0 Electrical Gremlin and weird Speedo Behavior
0 THE Trainspotting Thread
0 ‘15 Iron Chopped Fender/struts
Last Post: jjcsr74
0 The chicken or the egg (bent pushrod)
0 Dynojet Power Vision 2
Last Post: whittlebeast
0 2020 Sportsters
Last Post: jjcsr74
Last Post: jjcsr74
Last Post: LLOYD883
0 Rear hub lock nut
Last Post: randy3934
0 What Years Actually Fit the 1990 XLH?
0 One jug under the line...
0 New member
14 1974 Ironhead sportster xlch
Last Post: Kennyv
0 Lake Erie Ride Alums?
Last Post: Yakcm2
0 New LED headlight bulb. Highbeam aim wrong.
Last Post: Bikeaholic
0 started her in gear
Last Post: ezmerf
Last Post: Moon Wolf
0 Better late than pregnant
Last Post: Scott
0 '90 XLH-1157 Bulb not working correctly-Left Front
Last Post: Rollbar
0 A Day in the Life...
0 73 Ironhead
Last Post: mickey t
dtw757 (65), XLH75Rider (64), JRLang13 (57), Shaerona (55), christophe (52), collectovince (51), buckethead (41), Hang_Em_High (39)
Old 3 Days Ago
93trident's Avatar
93trident 93trident is offline
Sportster/Buell Model: 883c
Other Motorcycle Model: Triumph
Other Motorcycle Year: 1993
93trident is an unknown quantity at this point
Default Detachable pillion pad
Hi all is there a rear rack that has a detachable pillion pad on the market so you can use your rack then slap on the pad if the Old lady wants to go for a ride. Thanks
FFR
Old 2 Days Ago
BKB's Avatar
BKB BKB is offline
All the racks I've seen have weight limits. Usually 10 to 40 or 50 lbs. Even if you could find a seat to attach to the rack, I doubt if your lady is that light. Look for a detachable rack set up that you can pop off & a pillion that is easy to put on in it's place. I'm sure, with all the stuff available for these bikes, you'll find a combination that could work.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
