0 If you could only have one bike, would it be a Sporster?
0 AOL Blows
0 Electrical Gremlin and weird Speedo Behavior
0 THE Trainspotting Thread
0 ‘15 Iron Chopped Fender/struts
Last Post: jjcsr74
0 The chicken or the egg (bent pushrod)
0 Dynojet Power Vision 2
Last Post: whittlebeast
0 2020 Sportsters
Last Post: jjcsr74
Last Post: jjcsr74
Last Post: LLOYD883
0 Rear hub lock nut
Last Post: randy3934
0 What Years Actually Fit the 1990 XLH?
0 One jug under the line...
0 New member
14 1974 Ironhead sportster xlch
Last Post: Kennyv
0 Lake Erie Ride Alums?
Last Post: Yakcm2
0 New LED headlight bulb. Highbeam aim wrong.
Last Post: Bikeaholic
0 started her in gear
Last Post: ezmerf
Last Post: Moon Wolf
0 Better late than pregnant
Last Post: Scott
0 '90 XLH-1157 Bulb not working correctly-Left Front
Last Post: Rollbar
0 A Day in the Life...
0 73 Ironhead
Last Post: mickey t
dtw757 (65), XLH75Rider (64), JRLang13 (57), Shaerona (55), christophe (52), collectovince (51), buckethead (41), Hang_Em_High (39)
Old 3 Days Ago
ktate ktate is offline
Sportster/Buell Model: 1979 XLS
Sportster/Buell Model #2: 1980 XLH
Other Motorcycle Model: 1980 FLH
Other Motorcycle Year: 1978
ktate is an unknown quantity at this point
Default Staked Washer or Not?
Hello!
Quick question about OEM part #6860. Does this washer (1 inch ID x 2 inch OD x 1/8 inch) get staked to the primary or is it just dropped into the primary with the clutch adjustment assembly placed on top of it. My bike is a 1979 XL.
Thank you. Kim
Old 3 Days Ago
Air-Cooled Forever
The lock nut should hold that washer in place against the outer ramp assembly.
Old 3 Days Ago
Makes sense to me too. My service manual doesn’t mention staking but seems I recalled a YouTube genius speaking about staking it in place. Appreciate the quick reply. I’m going forward as you stated. Thanks again.
Old 3 Days Ago
Staking the washer is not necessary.
If you use my long nosed vise grip trick you will not drop any parts.
Grab the nut, with the grips tips against the cover to hold the mech in position.
After tightening the cover,
Run the adjusting screw in against the clutch before releasing the grips
Old 3 Days Ago
IronMick's Avatar
IronMick IronMick is online now
Rider Of The Iron Steed
This is what I do. learned the technique right here on XLForum
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Old 2 Days Ago
Got it! Appreciate the pic!
