0 compression problems
Last Post: swamp yankee
0 Hello from Murcia-SPAIN
0 Another 2 into 1 thread
Last Post: WI_duker
0 Late Ironhead cases interchangeability
0 Trackday Sportster
Last Post: Tag
0 1965 Ironhead in CT
Last Post: Scott
Last Post: oupa
Last Post: Tag
Last Post: oupa
0 Stock Straight Rate Fork Spring Weight on Rubbermount 1200C
Last Post: perfesser
0 It's Flame__'s Birthday!
Last Post: Edster
Last Post: gpydeski
0 Front brake lever
0 A Separate Speedo and Tach
0 1968 xlch
6 Is Your SPORTSTER...
0 Clutch Adjustment Woes
0 85 clutch adjustment woes
Last Post: Radheck
0 Cold?
0 Spokes question
Last Post: Scott
0 Who's still riding???
5 What's Your Temp Today
cobra0478 (75), Han (62), priell3 (58), Byrdman (54), jsta (52), YaeDio (51), doc (45), jfunk (45), lenainrouge (44), JohnDao (40), Razer883 (33), Slapchop68 (25)
Old 17th October 2018
My Arlen Ness Petcock (#07-030 - $35) has been functioning very well for years... It's got the 5/16" outlet so you'll need to work a bit to get a 1/4" fuel line on it...
2 Relax
sportysrock's Avatar
sportysrock sportysrock is offline
Sportster/Buell Model: XL883H/1200H
Sportster/Buell Year: '96
Sportster/Buell Model #2: XLCH 1000 w/elec. leg too
Sportster/Buell Year #2: '72
sportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond reputesportysrock has a reputation beyond repute
My Pingel doesn't have a reserve setting, but it was about 1/2 price in their bargain bin.
Sent with :-)
Ol' Big Daddy of the Dirty Ducks MC
I'll see your Twin Cams and raise you 2 more
Unlike the Internet, Al Gore DID INVENT Global Warming
Political Correctness never killed any terrorists.
seems odd.my Pingel has it.maybe it was race only?
Old 18th October 2018
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Year: 1974
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud of
Are you sure you didn't cross thread it?
Murphy's Law :vvet:
Old 29th October 2018
IronSporty79 IronSporty79 is offline
IronSporty79 is on a distinguished roadIronSporty79 is on a distinguished roadIronSporty79 is on a distinguished road
I thought I had it for a while, but fuel was still trickling out from the top of the nut. It could be the threads on the tank are so rusty and banged up that it's hard to get a good seal.
Anyway, I took the nut off my old petcock and put it on the new petcock without the filter and it works fine that way for now. I haven't had a chance to try a different brand of petcock, yet.
Old 1st November 2018
mikethebike61's Avatar
PINGLE....enough said
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Sportster/Buell Year: 1983
Other Motorcycle Year: 1969
You have to put the nut in the center of the threaded part of the petcock. As you tighten it, it draws the petcock and the tank bung together. If you don't start out with it centered, one end will bottom out in the threads before the other end is fully tight, and it will leak - either from the tank side or the petcock side, depending on which end the nut was closer to. By removing the plastic strainer, you have given more room for the assembly to get tight on that side, making up for starting the nut off-center.
Old 25th November 2018
I think I might finally have it, but 83LX, your explanation did help me imagine what was going on as I tightened it. If you don't REALLY tighten that nut against the bung, the plastic bottom of the strainer moves around and lets fuel through and up through the threads.
I've tightened the nut against the bung until it's basically out of thread and it seems to be good right now. We'll see what happens. I thought I had it last night, but I think it leaked some when the temperature dropped and the metal must have contracted or something.
If that doesn't work, has anybody used teflon thead tape to any success? If that doesn't work, I'll just get the Pingle.
try the Teflon tape.Pingel recommends that when installing their petcocks,to get the shut off valve to line up where you want it.
