0 100 vs 110 front tire
Last Post: lehel
0 Xr750
Last Post: toe
Last Post: CCC
Last Post: slojoe631
0 Riding music
Last Post: sprink
Last Post: ronccc
0 Xl???
0 Help me identify this washer
Last Post: SD_Mike
Last Post: randy3934
Last Post: Greasyman
0 Mikuni - hangin revs
0 Now I did it. Feel my pain
0 old parts
0 Digital speedo from street bob on a sporty?
Last Post: yelladox
0 Starter for an XLCH
Last Post: Imaginearat
0 Hello from LA area
Last Post: initiatebjj
0 so it's officially ended
0 Oil not returning to tank
Last Post: 1Scooter
Last Post: Nicktater
Last Post: The Doctor71
0 blocked main jet air bleed screw
Last Post: RussW
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Randy_rots
0 Runs great - stalls on clutch pull
Last Post: tedcool
texrex (68), jjluvstoride (55), luisbmns (50), njstoehr (44), tacho75xlh (41), 80ironhead80 (31), Xttrackerr (25)
Old 14th August 2020
heathkeenan heathkeenan is offline
Sportster/Buell Year: 1970
heathkeenan is an unknown quantity at this point
Unhappy 1970 XLCH Project Not starting
Hey guys, I need help. I put this bike together as a project bike and now I can't get it to start. When I turn the petcock on fuel comes out of the overflow hole every time (ZENITH CARB). I've tested the float, it floats. I've set the float to 3/16" drill bit as required, still leaks. I've taken the cup off to see if the jet turns off the gas when the float is up and it does. Put it all back together, it leaks. I have verified that when I turn the throttle there is gas in the carb.
I've also tried to spray starter fluid in the carb, bike won't turn over. I have verified a spark at both spark plugs. I have adjusted the valves, verified the timing at the cams where all the marks line up.
If anyone lives near Palmdale, CA I could use some help!!
Otherwise, any suggestions would be really appreciated.
Thank you!!
Old 15th August 2020
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Back to basics.
Engine needs 3 things to run.
Compression,
Correct air and fuel delivery (carburation)
A spark at the right time.
I Always begin with a compression test. Always.
Why ? because it rules out several problems at once. Are the cams times correctly ? Are the pushrods adjusted correctly ? are the rings not seating ? Is a piston holed ? Are the valves sticking/not seating ? Major head gasket leaks ?
This one simple test rules out so many things and the tool costs around $40. Or borrow your mates.
IF it passes muster on a compression test using Aerostart (starting fluid) will generally tell you if the problem is electrical or in the carby.
But that needs to be done corretly too.
With a leaking carb on there the engine may be flooded. Turn the tap OFF and turn the engine over 1015 times with the throttle held wide open.
Now open the throttle fully and give it a two second spray.
Close the throttle and kick it through with the ignition on 2-3 times.
The engine SHOULD run for a couple seconds.
If it only pops and coughs you have a timing issue.
I have done this routine at the race track for so many guys over so many years it staggers me.
At the track I can do it in about 5 minutes flat.
And it always gives me an answer. Or at least I know exactly where to look for the answer.
Tipofthelake Tipofthelake is offline
Sportster/Buell Model: XLS 1000
Sportster/Buell Year: 1979
Sportster/Buell Year #2: 1973
Other Motorcycle Model: Electraglide
Other Motorcycle Year: 2007
Tipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to all
As I mentioned in your other thread the first thing I would deal with is getting the carb not to overflow so as to eliminate the mess and fire hazard. As a follow up to that, how do you have the carb set up (jets, turns on the screws, etc. Hopefully someone who knows that carburetor can chime in with help on that.
Is this your first kickstart bike?
When you're kicking the bike (should be able to fill the carb and then turn the petcock off so as to avoid just dumping gas everywhere) what is your procedure?
randy3934's Avatar
did you install the float spring correctly?
Blind Owl
Fuel leaking from the carb does point to a problem with the needle and seat.
But unless it's flooded the engine the bike should still have been able to start with the Aerostart.
BigMek's Avatar
BigMek BigMek is offline
Sportster/Buell Year: 1982
I believe you can also borrow a compression test kit from Autozone or O'reilly.
Double-check your timing isn't off by one revolution.
XL1275 XL1275 is offline
XL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud ofXL1275 has much to be proud of
Getting spark is one thing, getting spark at the proper time is another.
