Last Post: mac93
0 Intro from New England
Last Post: peteskipsleg
Last Post: webman94
Last Post: Ben221
Last Post: The Crusher
Last Post: kmul
Last Post: Roosterman
Last Post: Jowniofownio
0 Feeling in trouble.
0 Engine dies when choke off
0 project 74 sporty
0 Parrothead's 2018 Spring Maintenance on old Sporty
0 ParrotHead's Mods For My "New" Sporty
0 first harley- help!!
0 Weekdays in PA, MD, DE (ETC.) - Meet & Greet - One Day Rides
0 Please help! Oil flow problem after rebuild
Last Post: kaveebee
Last Post: cotton1
0 99 1200s clutch drag
8 spark plug blew out on the freeway
Last Post: Ranchero50
0 Future of the sporty?
dtw757 (64), XLH75Rider (63), JRLang13 (56), Shaerona (54), christophe (51), collectovince (50), buckethead (40), Hang_Em_High (38)
blk80bike blk80bike is offline
blk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enough
Default Oil line routing on an 80
Does anybody with an 80 know the correct routing for the oil line that connects at the very top of the tank? Next to the battery clamp bracket.
To be clear .... I already have everything plumbed up property but I’m trying to figure out the correct factory path/route and/or the best route the rubber house is supposed to follow.
Right now I have the hose passing under the starter then up over the top of the starter solenoid, between the rear brake line and frame... then upwards through the opening where the oil filter bracket is attached to the frame.
I’m not sure if the hose is supposed to run bellow the solenoid or over top of it. It’s definitely cut short by the P.O. so it’s limiting my options at the moment. I can’t find a clear picture of how the factory actually ran the line so that it’s out of the way as it enters the battery holder area etc.
1980 Sportster XLH 1000
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
This is for my 1978. Should be the same for 1980. Check out all of the pictures...
Oil Line Routing
http://xlforum.net/forums/showthread.php?t=920306
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Thanks for the reply. I was looking at that very same post earlier before I asked. I was under the impression that the 80-81 oil tank was different in the way that the hoses attached up to the reservoir.
IronMick's Avatar
Yes, you are right about the oil tank being different. I should have read the first statement of your post more closely
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Model: Cushman Truckster
Other Motorcycle Year: 1990
Mine is tore down right now getting a face lift. This oil hose routing is original I think. Not sure since it was Nebraska motorcycle before I bought it and brought it to Texas.
Mine runs behind the solonoid cup, touching and grasping it like a lover in a curved embrace, going down to the oil pump fitting under the bike. Not over the top of it.
Hose behind solonoid in a curved embrace
Down around tranny case cover clamped to hug the cover tight.
Then on to the oil pump. The bike bottom is on the bottom of the orange lift. Wheels are off so I cannot show the underneath pictures till later. My thread is here.
http://xlforum.net/forums/showthread.php?t=2067738
Oh crap! Just found out my scooter is only worth 1500 bucks. Oh well.
Traveled to
Thanks for those replies. The 80 seems to be an odd ball year that’s why I wasn’t really sure. I think the problem for routing my oil line is because the P.O. must have cut around 2-3” off the hose, making factory routing pretty much impossible, since it’s to short now.
I think for now I’ll just get a brass coupling and 2 hose clamps... to add a small length onto the hose. It’s under the seat and above the battery, so it won’t stand out and be an eye sore. I’ll replace all the oil lines next winter since all of them are showing signs of age with rubbing and stuff.
I just need to find some motorcycle oil hose. I have a big spool of Goodyear automotive hose with the correct ID but the OD is way to thick to route around ... go figure.
rokytnji's Avatar
Here. I'll show you what I bought for new oil hose for my hardtail project .
Link
It is real shiny hose. Not the dull finish. I did not go with rubber because I live in the desert. My sun dry rots rubber.
IronMick's Avatar
The only local place that I find the correct ID & OD oil line is at an indie motorcycle shop that services vintage motorcycles. None of the usual auto supply stores have it.
