0 ***DK Custom-Limited Time Savings on ALL LED Lighting-See & Be Seen***
0 1200s mid throttle stumble
0 Headlight Modulator
0 XL883L 2006 coughing and backfiring
0 oil plug 1959 xlch
7 Tach Drive Magneto by Burkhardt questions
Last Post: T.B.Road
Last Post: moparnut72
0 Spark Plug
0 S&S IST Ignition
5 Jiffy Standing
Last Post: 83XLX
0 Do you like Brazilians???
Last Post: Bama Lee XLC
0 Both of my Sportsters going to the auction now
0 Filters
0 New stuff from Harely
0 Getting a face full.
0 In PA Or Nearby
7 Starter Problems???
0 G,Day from Gods Country.
Last Post: Blowupster
Last Post: maverick31210
0 1200 after market coils
Last Post: Metalhead86
0 71 -80 magneto
Last Post: T.B.Road
0 Oops.... Nicked the Steering Stem
Last Post: Sadsack
0 Bendix / Zenith questions
Last Post: randy3934
Last Post: kmul
6 What gasket sealer goo do you like?
Last Post: KCinSB
  #71
Old 5th November 2015
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
2007 XL883 Sportster owned by XL Forum Member joes95bobber, equipped as follows.
HAMMER PERFORMANCE 110+Hp 1250 Conversion Package, consisting of:
Click Here to Contact Me
Old 25th April 2016
aswracing's Avatar
2007 XL883 Sportster owned by HAMMER PERFORMANCE, equipped as follows.
HAMMER PERFORMANCE 120+Hp Conversion Package, consisting of:
Disclosures:
  • Cranking compression is 200psi on both cylinders. It's running on 92 octane pump gas from the local Conoco.
  • This was a 5th gear pull. We did not do any 4th gear pulls.
  • We had no air cleaner in place for this pull, as the air cleaner that comes with the HPI throttle body is too small. We're developing an Air Hammer air cleaner for this application.
Details of the build:
  • SLEDGE+ CNC head porting service includes welding up the floors in the ports so that we can shape the short side better.
  • In addition to the floor work, we also altered the valve angles in these heads. We did this so that we could fit larger 2.020" intake and 1.630" exhaust valves (standard SLEDGE service includes 1.980" intake and 1.610" exhausts).
  • We also went to the latest high tech valve springs. Although our standard springs included with the SLEDGE service are state-of-the-art in beehives, they weren't up to the job with these new larger valves at higher rpm. These new springs are the next generation. They are not a beehive and not a straight wound spring either.
  • Another valvetrain change is a switch to 1.725 ratio rocker arms. We raised lift because bigger valves bring in most of their flow gains at high lift. But the plastic anti-rotation device for the lifters, used in all 06+ Sportsters, effectively limits what you can do with lobe lift. So we went to high ratio rockers instead.
  • The larger, more spread apart valves requires a bigger bore to work. That's where the 1275 kit comes in.
  • The new 1275 kit we're introducing with this package remains a drop-on, just like the 1250. No case boring is required. The additional bore size is made possible by using a special 120,000psi tensile strength steel liner. This is a significantly more expensive product, and as such, it's only applicable to our top of the line package.
  • This motor is still using it's stock fuel injectors and stock fuel pressure.
You can read more about this package here: http://www.hammerperf.com/883conversions.shtml#120hp
Also, there's a discussion thread about it here: http://www.xlforum.net/vbportal/foru...44#post5374944
Old 28th April 2016
DeadeyeRich's Avatar
DeadeyeRich DeadeyeRich is offline
Sportster/Buell Model: XL 1200L
DeadeyeRich has much to be proud ofDeadeyeRich has much to be proud ofDeadeyeRich has much to be proud ofDeadeyeRich has much to be proud ofDeadeyeRich has much to be proud ofDeadeyeRich has much to be proud ofDeadeyeRich has much to be proud ofDeadeyeRich has much to be proud ofDeadeyeRich has much to be proud ofDeadeyeRich has much to be proud ofDeadeyeRich has much to be proud of
ENGINE: '08 1200 Low
CRANK: Buell XB/XR 1200 Crank and Sprocket assembled by Hammer Performance
PISTON/CLINDERS: Hammer Performance 1250 kit, 10.5-1
HEADS: Stock heads and valves.
CAMS: Hammer Performance Impact 560
AIR CLEANER: Hammer Performance Crush 2.25 in. centered air cleaner.
PUSHRODS: Sledge Hammer Pushrods .050 shorter than stock
CLUTCH: Energy One
BREATHER: Horseshoe design head breather kit with filter and catch can.
Cometic gaskets.
EXHAUST: Patriot Defender
TUNER: Power Vision
DYNO: Performance Choppers, El Cajon, CA
DYNO TECH: Mikey
DYNO RESULTS: 104.71 HP/87.29 Torque @ 6400 RPM
Old 13th June 2016
aswracing's Avatar
2014 XL1200/1250 owned by a Charlie's Harley-Davidson customer
Comments: Typical Thunderheader torque curve ... pushing back badly down low, a real hard pull right in the middle (hence the big peak torque number), pushing back again on top, albeit not as badly. It just doesn't diffuse well, it concentrates all it's pull at one rpm to the detriment of others. Unfortunately, a lot of pipes do this.
Since power is just torque times rpm, the drop in torque at high rpm hurts the top power number. In our testing, the Patriot beat the Thunderheader by 6hp on top.
Despite the pipe choice, it's still a very respectable result. Congrats to the guys at Charlie's HD on a job well done.
Old 14th June 2016
aswracing's Avatar
Default And another 2014 XL1200
2014 XL1200C owned by a valued HAMMER PERFORMANCE customer
The same package as the previous post. Different exhaust and air cleaner though. Also the solid "C" rear wheel.
Last edited by aswracing; 15th June 2016 at 04:26.. Reason: added air cleaner info
Old 29th June 2016
aswracing's Avatar
Default And another result from the 100+hp conversion package ...
This is a 2008 XL883/1250 owned by a valued HAMMER PERFORMANCE customer. Equipped as follows:
HAMMER PERFORMANCE 100+hp XL883/1250 Conversion Package, consisting of:
Comments: More than 3 years after we first introduced it, the 100+hp conversion package continues to be one of our most popular packages, and results like this are the reason why. It's put a lot of 883's into the 100 club over the years.
Old 12th July 2016
aswracing's Avatar
Default The 100+hp package strikes again ...
This is a 2011 XL883/1250 owned by a valued HAMMER PERFORMANCE customer. Equipped as follows:
Comments: exact same setup as the previous chart, with essentially the exact same result. Like I said, it's a very popular package.
This one was particularly gratifying to see, as the customer first went through some trials and tribulations attempting to build on his basic conversion and not getting to where he wanted to be, or even getting to where we thought he would be for that matter. We hate seeing a customer come up short of his goals, and it causes us stress. But then he stepped up and did it right and went with the full 100+ package and got this. So we were as happy to see this as he was!
Old 18th November 2016
doomedcobra's Avatar
doomedcobra doomedcobra is offline
Sportster/Buell Model: XL883N Iron
doomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to alldoomedcobra is a name known to all
89.06 HP 85.35 TQ
ENGINE: 2011 XL883N
LOWER END: Stock
CYLINDERS: Hammer Performance Large Fin 1250
PISTONS: Flat Top (supplied with 1250 kit)
HEADS: Screamin' Eagle Pro CNC Ported Factory Cylinder Heads
ROCKERS: Stock
PUSHRODS: XL PERFECT FIT PUSHROD KIT, -.050
LIFTERS: Stock
CAMS: Andrews N3
AIR FILTER: K&N 63-1126P Performance Intake Kit w/ Bikers Choice Breather Kit
EXHAUST: Vance & Hines Short Shots Staggered
COILS: Stock
CLUTCH: Barnett extra plate kit w/ XL1200 diaphram spring
TRANSMISSION: Stock
OTHER MODS RELATED TO ENGINE: NGK DCPR9E Standard Spark Plugs, SE Spark Plug Wires, Custom Dyno Tune w/ SE Super Tuner Pro
Remove some stuff. Add some stuff. Rinse and repeat.
Old 24th January 2017
aswracing's Avatar
This result shows the difference between an 883-1250 conversion and a 1200-1250 conversion. It's the same bike, and everything is the same except for the heads and the matching pistons. Specifically:
  • 2007 XL883
  • Stock 1200 heads in blue, stock 883 heads in red
  • HAMMER 1250 kit with flat top 1250 pistons in blue, reverse dome 1250 pistons in red (both configurations have a 10:1 compression ratio)
  • Stock "W" cams
  • Patriot Defender exhaust
  • Air Hammer air cleaner
  • Tuned with a Powervision
I generated this chart because I got an email from a customer asking me if 883 heads are better for bottom end and 1200 heads better for top end. I realized I had all the dyno data so I just made the chart to answer his question. I thought it might be of general interest too, so I'm posting it.
As you can see, the smaller valves and ports of the 883 heads did not really bring much of anything to the bottom end power. In fact, the difference is within the repeatability of the measurement, especially considering that these results were not taken on the same day. I would not read anything into that minor difference down low, it may not be real.
On the other hand, there's no mistaking the top side advantage to the 1200 heads. The bigger valves and better ports make a big difference.
No big revelation here, just thought some folks might find it interesting.
Old 28th August 2017
vaakko's Avatar
vaakko vaakko is online now
Sportster/Buell Model: XL1200X forty eight
Sportster/Buell Year: 2012
vaakko is a splendid one to beholdvaakko is a splendid one to beholdvaakko is a splendid one to beholdvaakko is a splendid one to beholdvaakko is a splendid one to beholdvaakko is a splendid one to beholdvaakko is a splendid one to beholdvaakko is a splendid one to beholdvaakko is a splendid one to beholdvaakko is a splendid one to beholdvaakko is a splendid one to behold
109hp @ 6650rpm and 96ft-lb @ 5179rpm (chart has torque in Nm)
2012 Sportster XL1200:
- Hammer Performance 1250 kit with 10.0:1 flat tops
- Hammer Performance crush air cleaner
- Dynojet PowerVision and TargetTune (wideband lambdas + closed loop)
- Screamin Eagle .536 cams
- S&S adjustable push rods & collapsible covers
- Bronze oil pump drive gear
- Stiffer (20%) clutch spring
- Ported 1200EFI heads with 1,850" intake valves and stock exhaust valves
- Exhaust is HEAVILY modified V&H RSD Tracker 2-1
- All the rest is stock
Difference with the two results are head pipes (properly tuned for each pull). Lower results had original head pipes i.e. rear cylinder's head pipe was shorter than front cylinder's. Top numbers have rear cylinder's head pipe modified to same length as the front has.
Build thread: http://xlforum.net/forums/s....php?t=2037381
My YouTube channel: https://www.youtube.com/channel/UCPKieV9S65bZt5lH6iA7yEA
