0 Hello from California
6 Calling all musicians
Last Post: DirtyHarry68
0 Buying another IH
Last Post: jharback
0 TC88a DIY Power adapter ?
0 Gasket goo or not to goo
Last Post: rog
0 Gasket set recommendations
Last Post: ironkiwi
0 left him stranded
0 Clutch WILL NOT adjust to disengage!
Last Post: THEWILDONE
0 Just wanted to thank everyone
Last Post: jordan1200
0 Evolution Performance Bolt-On Big Bore Kit
Last Post: jharback
0 Scored new to me used tins
Last Post: jharback
0 hello from a long time lurker
Last Post: jharback
Last Post: FreakyRF
0 vibration problem solved - CHECK YOUR FRONT ENGINE MOUNT BOLT!!
0 Handlebar diameter
Last Post: ironkiwi
0 My 1250 to 1275 build
0 1977 Ironhead big fuel tank options
0 Parts interchange
0 Help ID’ing... Heads and jugs are weird?
Last Post: Bryan1976
0 The Oil Leak Rabbit Hole
0 2004 rear mast cylinder
0 25 April
Last Post: Marcos.Bonfim
0 T bars or Apehangers???
Last Post: spitfirechopper
0 THE Hockey Thread
Last Post: Airbozo
0 Locked up rear wheel
0 Intermittent Starter
cylinder, jugs, top end rebuild
Old 13th September 2018
T_worth T_worth is offline
Sportster/Buell Model: Xlh 1200
Sportster/Buell Year: 96
T_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura about
Default Mystery Cylinder Symbol
Im in the middle of a Top end rebuild on my 96' sporty 1200 and I discovered that I don't have the same cylinder jugs as the other sportys in my garage. Can anyone identify this symbol/brand? Its on both cylinders in the same corner. (photo https://ibb.co/cdmH0U)
Glamazon Glamazon is offline
Senior Bike Builder
Sportster/Buell Model: xl883r
Sportster/Buell Year: 2014
Has it always been a 1200? Could be aftermarket 1200 cylinders
Not sure. I picked up this bike 2 months ago from someone. I think it has 2 previous owners (to my knowledge). The VIN # states it’s a 1200. Someone has installed S&S pushrod kit and some kind of aftermarket valve springs (my bike has 3 springs on each valve instead of the factory 2). Need to check if I have S&S cams too.
So it’s possible these jugs are aftermarket. I just would like to know what brand or what the symbol is/means.
Air-Cooled Forever
I think that is a "Graphic symbol" for an A. I've seen it before but can't remember where.
Old 14th September 2018
I emailed a photo of my cylinder to my local HD dealer. They researched it, and turns out. Its a Drag Specialities jug. They said I should I should get drag specialities gaskets, but I had already ordered the Cosmetic gasket kit for my Top end rebuild. Hope the gaskets are fine.
Air-Cooled Forever
I knew I'd seen that symbol before, glad you got it figured out.
Medyo Bastos Medyo Bastos is offline
Sportster/Buell Year: 1966
Medyo Bastos is an unknown quantity at this point
I thought it was an adidas symbol...
Air-Cooled Forever
Subliminal messaging, 'if you can see this symbol, you must be walking','Walk in the best "A" '
Old 15th September 2018
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Model: XL883
Sportster/Buell Year #2: 1999
There's a company that imports a ton of "replica" products from Taiwan, who then sells to distributors. In some cases the products they bring in are sold under private label deals. So the distributor puts his sticker on the box and then sells to dealers as his own branded product.
That's what this product is. It's sold under four different brand names that I'm aware of, possibly more. Drag is one of those companies. You can go buy the exact same cylinder from V-Twin or Custom Chrome, for example. I've also seen it branded as a Sifton product.
The company that imports it keeps a low profile, and won't sell to dealers. They're an importer and they sell to distributors only. Just figuring out who they were was difficult.
It's a pretty well made cylinder, too. It used to be a good lower-cost alternative to the factory piece. But now it costs almost as much as a new cylinder from HD, at least at the retail level. Popular with Indy shops who would rather buy a cylinder from their distributor with good margins instead of buying parts from an HD dealer at a jobber price.
Click Here to Contact Me
Old 21st September 2018
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond repute
Good job researching that foundry mark!
What is the company name?
