0 Never seen this before...
0 The Oil Leak Rabbit Hole
0 2020 Sportsters
Last Post: Lone Rider
0 First startup
0 1969 XLCH Speedo
Last Post: Moon Wolf
Last Post: mickey t
0 Sadly Leaving
Last Post: Sprtstr1200s
Last Post: Captain Johnny
0 Spark plugs
0 Another Sporty ADV Build
Last Post: shreksbro
0 New 2020 Sportsters!
Last Post: Clevspeed
0 What have I done wrong? (Cleaned Carb, Now Won't Start)
Last Post: DYLAN
Last Post: groovemeisterus
5 Replaced bad VOES... Engine sounds weird when hot and idle
0 wheel swap
0 Bike can't go over 75miles.
0 Piston ID
Last Post: Nitro57xl
0 1969 XLCH Pics
qrtsteve (65), NoRemorse (51), johnboy (50), bmonty72 (47), superscythe (46), arlen (41), Sonofnothing (35), grahamc (34)
Old 3rd July 2019
rortiz76 rortiz76 is offline
Sportster/Buell Model: iron 883
Sportster/Buell Year: 2016
rortiz76 is an unknown quantity at this point
Default Primary grinding sound
I have a iron 883 2016 and couple month ago start a grinding sound on the primary when decelerating, i consult with a mechanic and finally find a clutch hub bearing its moving and its not supposed too, so i replaced it and the grinding sound goes off in some of the gears but left it in 4th gear when decelarating. Couple days ago i take the primary off to check everithing again and i see that the clutch hub have a movement just like the other bad bearing. So i not sure how two bearing can be damaged. I am replacing again. The sportster have only 4000 miles. Maybe the mechanic replacing the first bearing damaged it, maybe its why still grinding? When i pull the clutch stop.
