Last Post: jzink0883
0 Never seen this before...
0 The Oil Leak Rabbit Hole
0 2020 Sportsters
Last Post: Lone Rider
0 First startup
0 1969 XLCH Speedo
Last Post: Moon Wolf
Last Post: mickey t
0 Sadly Leaving
Last Post: Sprtstr1200s
Last Post: Captain Johnny
0 Spark plugs
0 Another Sporty ADV Build
Last Post: shreksbro
0 New 2020 Sportsters!
Last Post: Clevspeed
0 What have I done wrong? (Cleaned Carb, Now Won't Start)
Last Post: DYLAN
Last Post: groovemeisterus
5 Replaced bad VOES... Engine sounds weird when hot and idle
0 wheel swap
0 Bike can't go over 75miles.
0 Piston ID
Last Post: Nitro57xl
0 1969 XLCH Pics
qrtsteve (65), NoRemorse (51), johnboy (50), bmonty72 (47), superscythe (46), arlen (41), Sonofnothing (35), grahamc (34)
Old 21st February 2018
DK Custom's Avatar
Sportster/Buell Model: 883L
Default **DK CUSTOM - Pro-Action Street Series Shocks**
DK CUSTOM PRODUCTS
MADE IN THE USA!
CUSTOM DESIGNED & DEVELOPED SHOCKS
For
Harley-Davidson
Sportster ~ Dyna ~ Touring ~ Trike
Go HERE for a full report on our rear suspension testing!
The T6061 Billet aluminum bodies house a unique 3-stage progressive valving system for compression, and a 2 stage rebound system. Coupled with "fit to you" coil over springs that have an adjustable pre-load, you will be amazed how much smoother and more stable your bike/trike will ride.
These Street Series Shocks are available in 3 lengths: 11.25", 12.25" & 13.25".
The travel is 2.5", 3" & 3.5" respectively. Combined with less sag than the stock shocks, this gives an average of 33% - 50% MORE Travel. (Unless otherwise requested, we will send the OEM length shocks for your bike to you)
When you order you will be asked some easy questions. Your answers give us the information needed to use the correct spring rate for your shocks, as well as giving us the info needed to adjust the pre-load and rebound for you. This way when you receive the shocks they are already set-up for you. Simply bolt them on and ride!
You can Lower or Increase the Height of your Bike by requesting a different Length Shock. We will send the stock height shocks for your bike, unless you request in the "Special Instructions", at checkout, 1" shorter or 1" taller Shocks.
Go HERE for more photos and full details!
Cristy
See Black Hills, Grand Teton, & Ozark Ride Report HERE
www.DKCustom.com
Phone: 662-252-8828
Text: 662-420-4891
DK Custom YouTube Videos
Lots of Photo's at Pinterest
Old 30th August 2018
DK Custom's Avatar
Get 100% improved ride quality with Pro-Action!
Go HERE for photos and details!
Old 4th January 2019
DK Custom's Avatar
Check out our Testing Reports on Both Front & Rear Suspension!
Front Suspension Testing Report
Rear Suspension Testing Report
Old 3rd June 2019
DK Custom's Avatar
Check out this How To Install Video:
DK Custom's Avatar
Check Out This How-To Video!
DK Custom's Avatar
