0 Never seen this before...
0 The Oil Leak Rabbit Hole
0 2020 Sportsters
Last Post: Lone Rider
0 First startup
0 1969 XLCH Speedo
Last Post: Moon Wolf
Last Post: mickey t
0 Sadly Leaving
Last Post: Sprtstr1200s
Last Post: Captain Johnny
0 Spark plugs
0 Another Sporty ADV Build
Last Post: shreksbro
0 New 2020 Sportsters!
Last Post: Clevspeed
0 What have I done wrong? (Cleaned Carb, Now Won't Start)
Last Post: DYLAN
Last Post: groovemeisterus
5 Replaced bad VOES... Engine sounds weird when hot and idle
0 wheel swap
0 Bike can't go over 75miles.
0 Piston ID
Last Post: Nitro57xl
0 1969 XLCH Pics
qrtsteve (65), NoRemorse (51), johnboy (50), bmonty72 (47), superscythe (46), arlen (41), Sonofnothing (35), grahamc (34)
KrakerJak KrakerJak is offline
Sportster/Buell Model: Xlch
Sportster/Buell Year: 1972
Sportster/Buell Model #2: 883-1200 converted
Sportster/Buell Year #2: 1991
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1975
KrakerJak is an unknown quantity at this point
Default Evo Sportster Secondary Drive Sprockey Question
I currently run a chain conversion on my 91 sporty. I am possibly swapping the engine out from a 99 donor bike. My question is will my drive sprocket swap from the 91 to the 99? Research shows there was a change in design from early 94 to late 94. I am just trying to get an idea of how much alteration this engine swap will need as I am pressed for time. Thanks in advance for any input.
Here's a small section in the Sportsterpedia regarding chain conversion on EVO models:
http://sportsterpedia.com/doku.php/t...nversion_parts
