0 Rare As Hens Teeth? (Stock Parts Secondhand)
3 Wtb, Wts, Wtt, Wtg (EFIs)
Last Post: toomuchstuff
0 XLCH chainguard
Last Post: 1200CustomHD
0 Big bore Stroker problem
0 New oil tank
0 Oil leaking
0 SE.536 cams, who has a set sitting around
0 Repainted my bike
0 Done for now (no really)
Last Post: tizard
Last Post: chilly
Last Post: XL1275
0 One More Ohio Meet & Eat?
0 It's Glamazon's Birthday!
0 newbie
0 Gear Spacing Question
0 FAF Sporties
Last Post: drgonzo21
0 Any wealthy forum members?
Last Post: Full-Bore12
0 30 tooth pulley? For ‘04-06
Last Post: Mike1nw
  #31
Zari Zari is offline
Sportster/Buell Model: Xlh 1000
Sportster/Buell Year: 1982
Zari is an unknown quantity at this point
maybe the reson is look in pic att you see bottom original cover with lip
and above new one without lip Im understand I need cork seal not o-ring
IMG]https://photos.google.com/photo/AF1QipN6eLpdJe0CiuOF8obq4XF6hhzRCi45iB98NC8y[/IMG][/URL]
look at pic attc you see At the bottom original cover with lip above new one without lip
maybe I need to put cork seal not o-ring
https://photos.app.goo.gl/UVYmvAjrQdBpJxp49
the new cover without lip uses flat seal cork or silicone.do you have a mixed set now?your year should have o-rings.''when in doubt do what the factory did'' D.D.
GA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant futureGA_Ironhead has a brilliant future
Zari, Google wants a signin to see photo. Try again?
How do stink bugs live with themselves?
Senior Master Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Cork on flat style (early)
O ring on lip style (later)
Just like Bruce said ^^
randy3934's Avatar
in your pic the upper tube takes cork, the lower uses "O" ring, I have a couple bikes with mixed cork and "O" ring tubes hahahaha
Still leaking with the new flat cover with cork seal what can I do????
Yes less but still there
randy3934's Avatar
try turning the tube a bit with your fingers, should stop the leak.
