0 Shock search is OVER !!!
Last Post: Bikeaholic
Last Post: Heff
0 Oil leaking
Last Post: Zari
0 Issues with progressive springs
Last Post: thefrenchowl
0 excellent color
0 top end rebuild
Last Post: eisenhead
0 Vulcan Mid Glide Triple Tree Conversion Set
Last Post: motorfish
0 Sportster 48 in a Nighster
0 Clutch blow up
Last Post: Tonimacaroni
Last Post: 1skullster1
0 New oil tank
0 weight loss thread
Last Post: catpepper
0 Fork seal follow up...Stop me if I'm being stupid.
Last Post: 1200CustomHD
0 Ironhead Exhaust Poll
0 my daily driver
Last Post: 84rzv500r
0 my sunday driver...
0 compression test question
0 Cruising RPMs
14 Buell back in business?
0 Swing arm pivot
0 Do not buy this oil!
seajay, Hugh Betcha (74), jimhd89 (71), JayFL459 (71), Big Al (64), dakota_dj (63), 10walt (61), kiltbill (61), timsvalk (60), horsewriter (55), Benetampa (43), hobson8494 (36), Joker8494 (36), 8ball (31)
  #101
Old 3 Weeks Ago
We use tractor paint on our race car frames.
Next best thing to powder coating.
Old 3 Weeks Ago
It seems to me that engine enamel is a high heat paint, may not be suitable or best choice for a frame
i'm thinking you would pay more for the heat resistant paint.
Old 3 Weeks Ago
wedge's Avatar
wedge wedge is offline
Around here, people have given up on powder coating. Once it gets chipped it's hard to repair and corrosion takes hold under the coating. With any good industrial enamel or urethane you can do touch up and never have to worry about it.
Old 2 Weeks Ago
Gold Member's Avatar
Sportster/Buell Year: 1972
Here's what I be doing. VHT paint. $9.00 a can. The internet says it's good for motorcycle frames. It's got ceramic in it. I assume that makes it chemical resistant. Well anyway Imma try it. The can is a little confusing. It says recoat inside of an hour or after 7 days once the paint is "cured." It also says it needs to be "cured" at 200F for an hour.
I contacted VHT and asked if I could cure it at a lower temp on my woodstove and they said it will never cure at 100F no matter how long you try. I can get 200F on my stove top with an old barbecue lid over it. Borrowed Puppy Love Lip's oven thermometer.
The internet says engines run at up to 235F, so if I get it up over 200F but not over 235F I will probably be all right. Then again the paint can handle up to 550F for short periods.
It is supposed to be chemical resistant once cured, so it should work for my schmancy tank.
It dries to handle in 3 hrs so tomorrow I'll fire up the woodstove again and cook the swingarm.
The funnel on the wall is my urinal. It is a man cave after all. Haha I just noticed I miss a lot.
Stop by my build thread:
Old 2 Weeks Ago
I "cured" the swingarm well over an hour on the stovetop at 200F and over at times. I can't say I'm all that impressed yet. I can scratch the paint off with my thumbnail. I hope it off-gasses with time and hardens. Next up will be stripping the frame. The weather is supposed to be good tomorrow for that.
Old 2 Weeks Ago
I kinda take it back about the VHT paint being soft. Now that it's the next day and cooled off, I can't scratch it with my thumbnail, and I think it's pretty hard. So far, for a low rent paint job, I think I can recommend it. There's no paint smell to it today, and i think it's pretty much about totally off-gassed.
