Last Post: Eugis
0 2001 sportster oil line question
0 Do not buy this oil!
0 Issues with progressive springs
Last Post: APJ CUSTOMS
0 Cam chest vent fitting
0 top end rebuild
0 Vulcan Mid Glide Triple Tree Conversion Set
Last Post: Dariusz
0 Sportster 48 in a Nighster
Last Post: Dariusz
0 Ironhead Exhaust Poll
0 Shock search is OVER !!!
Last Post: XL1275
0 Oil leaking
Last Post: Zari
Last Post: thefrenchowl
0 excellent color
0 Clutch blow up
Last Post: Tonimacaroni
0 New oil tank
0 weight loss thread
Last Post: catpepper
0 Fork seal follow up...Stop me if I'm being stupid.
0 my daily driver
Last Post: 84rzv500r
0 my sunday driver...
0 compression test question
seajay, Hugh Betcha (74), jimhd89 (71), JayFL459 (71), Big Al (64), dakota_dj (63), 10walt (61), kiltbill (61), timsvalk (60), horsewriter (55), Benetampa (43), hobson8494 (36), Joker8494 (36), 8ball (31)
Old 15th June 2020
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
You will see when you pull the sprocket cover of that is where the problem is. The leaks there are usually pretty obvious.
If it looks like it's coming from the M/S seal then pull the sprocket.
You may need a two arm puller to get the sprocket off.
Old 16th June 2020
doodah man's Avatar
Originally Posted by Ferrous Head View Post
...You may need a two arm puller to get the sprocket off.
In addition to this, if the sprocket can rotate/has too much clearance between the splines of the sprocket and shaft, you might want to consider a new sprocket.
Old 21st June 2020
Roane Roane is offline
Roane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to all
ok, thank you
Old 22nd June 2020
I've just never done it, so a little uncertain but doing is how you learn I find. I found my manual and will look there as well. I saw on the forum that Ironmick just advises using a permex gasket.
Old 22nd June 2020
Originally Posted by Roane View Post
... I saw on the forum that Ironmick just advises using a permex gasket.
Keep in mind that I am not nearly so expert on IronHeads as many of the other long term members. My intro from the top of the forum...
Mick, IronHead Forum Moderator, Introduces Himself
http://xlforum.net/forums/announcement.php?f=7&a=16
I believe that I was asked to moderate this forum because in the beginning I made a number of contributions to the Stickys and generally set a good example. My contributions have all been beginner level, technical topics - which as a retired professor has always been my main interest. My actual background is in traditional sciences, first chemistry and then computer science...
My AutoBiog from some years ago
https://mdawdy.webs.com/OffPage/Work/AutoBiog.htm
Old 22nd June 2020
sleighcrane's Avatar
sleighcrane sleighcrane is offline
Sportster/Buell Year: 1967
Other Motorcycle Model: FLHR
sleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to all
Hey Mick you make a great cup of coffee as well
Old 22nd June 2020
You are welcome here any time
Old 22nd June 2020
Understood IronMick. It was just an idea that seemed to have a good bit of merit.
I saw your site awhile back and really enjoyed looking through it, and I've been quite appreciative that you have continued teaching here...
Old 23rd June 2020
I love those too rare occasions when an XLForum member comes by and we pass some time together. If any of you are ever in this area please contact me.
Old 23rd June 2020
11B40 11B40 is offline
Mick is a great HD guy. He knows what he knows and has the gift of silence. Both valued talents.
