Last Post: Eugis
0 2001 sportster oil line question
0 Do not buy this oil!
0 Issues with progressive springs
Last Post: APJ CUSTOMS
0 Cam chest vent fitting
0 top end rebuild
0 Vulcan Mid Glide Triple Tree Conversion Set
Last Post: Dariusz
0 Sportster 48 in a Nighster
Last Post: Dariusz
0 Ironhead Exhaust Poll
0 Shock search is OVER !!!
Last Post: XL1275
0 Oil leaking
Last Post: Zari
Last Post: thefrenchowl
0 excellent color
0 Clutch blow up
Last Post: Tonimacaroni
0 New oil tank
0 weight loss thread
Last Post: catpepper
0 Fork seal follow up...Stop me if I'm being stupid.
0 my daily driver
Last Post: 84rzv500r
0 my sunday driver...
0 compression test question
seajay, Hugh Betcha (74), jimhd89 (71), JayFL459 (71), Big Al (64), dakota_dj (63), 10walt (61), kiltbill (61), timsvalk (60), horsewriter (55), Benetampa (43), hobson8494 (36), Joker8494 (36), 8ball (31)
  #31
Old 2 Weeks Ago
11B40 11B40 is offline
When using any fastener into an aluminum part: Aluminum always loses. Look at the hundreds of timing holes with a wine cork in them. In '66 they went to a 7/8 headed plug and you couldn't get a good purchase on the plug, so thousands of timing holes were saved from idiots.
Old 2 Weeks Ago
Roane Roane is offline
Roane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to all
That’s why mine is probably still intact... for now.
Doc308 Doc308 is offline
Sportster/Buell Year: 1969
Other Motorcycle Model: Panhead EL
Other Motorcycle Year: 1948
Doc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to allDoc308 is a name known to all
Regarding the length of the oil line, I had a '59 Ch which leaked from one. No matter how carefully I reset and tightened the nuts, it would leak. The solution was that I purchased same diameter tubing from an auto parts store ( if I recall correctly, the tubing was for an auto transmission cooling line) and cut the length slightly longer that the stock one and slid the stock rubber seal into place. The leak never returned.
Senior Master Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
You can also cut some longer rubber sleeves from some 3/16” vac hose from the parts store. This allows them to compress a little tighter around the tube.
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
The braided stainless steel ones work just fine.
unless you have a magneto like Doc's'59. or have you managed to make them work on your XLCH?
Blind Owl
Not sure what peoblem the Doc might have had but the ones I've used worked OK.
They have enough length to accommodate taller cylinders. So you can run them with some of the aftermarket cylinders.
The point of interference with the upright mounted magneto is just where the ground screw sticks out. With Morris (and J Hunt ?) this doesn't pose a problem. In fact you can use two straight lines with them The ground screw is re-located on the Morris mags.
right.i was referring to the bend for the ground screw for the F-M units.i have a Morris MM3 but i choose to keep the oem look.as a matter of fact i just ordered some new cad plated ones from ebay to replace my chrome ones i put on many years ago when chrome was popular.
Blind Owl
I'm finally getting around to putting the top end back on my 58 CH Stroker engine. And I'm PROBABLY going to use the oem lines.
But they can be a pain at times. And I forgot to measure the cylinders on this engine. They might be stock height, they might not.
The braided ones are easier to use on an engine that comes apart a lot.
The braided hoses for the rocker box oil feed tend to leak between the fitting and the hose after a time.
I take them off and toss them.
Use a VTwin 40-0116 oil line kit for clearance on a mag.?
