0 XLCH chainguard
0 Big bore Stroker problem
0 New oil tank
0 Oil leaking
0 SE.536 cams, who has a set sitting around
0 Repainted my bike
0 Done for now (no really)
Last Post: tizard
Last Post: chilly
Last Post: XL1275
0 One More Ohio Meet & Eat?
0 It's Glamazon's Birthday!
0 newbie
0 Gear Spacing Question
0 Strengthening 73 rear shock structure
Last Post: mikethebike61
0 FAF Sporties
Last Post: drgonzo21
0 Any wealthy forum members?
Last Post: 1200CustomHD
Last Post: Full-Bore12
0 30 tooth pulley? For ‘04-06
0 Rare As Hens Teeth? (Stock Parts Secondhand)
0 Disassemble tranny HELP
0 Reassemble engine
0 1991 Manifold Bolt Trivia (?)
Old 6th September 2020
Zari Zari is offline
Sportster/Buell Model: Xlh 1000
Sportster/Buell Year: 1982
Zari is an unknown quantity at this point
I just replace 2 o-ring One up and one down I bought them in Hardware store for 1$ and for now everting is O/K
Old 7th September 2020
still leaking today after short drive evidence of oil same place
maybe wrong o-ring type should buy the cork o-ring ?????
Hippysmack's Avatar
Never heard of a cork O-rings.
Are the tubes holding oil?
If so, see this piece in the Sportsterpedia: Restricted Tappet Guide Drain Channel
http://sportsterpedia.com/doku.php/t...#pushrod_tubes
Last edited by Hippysmack; 7th September 2020 at 22:12.. Reason: moved article, updated link.
Senior Master Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Cork seals are used on earlier models. O-rings are used in the late models. The terminology is used incorrectly.
Post some pics of your leak area. I was unable to view your pic in the earlier post (shows 404??). Perhaps your leak is coming from upper end oil sleeve? Or tappet block?
XL1275 XL1275 is offline
Sportster/Buell Model: XL1275 Roadster
XL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant future
What was the material? The ones I installed on mine were brown. I'm assuming they are Viton by the color.
the o -ring black
here is link to pic
https://photos.google.com/share/AF1Q...RhbmtFbUlBTXVn
Old 8th September 2020
Not a very clear pic, but looks like debris in the block near the o-ring area. Get the proper o-rings, pull the pushrod and remove the block itself. Thouroughly clean the area and reassemble. Verify that you in fact do have the o-ring style tube prior to getting the o-rings. Also be certain the oil is not migrating from the fitting feeding the top end directly next to it. It looks like the feed tube may have been comprimised at one time allowing oil to migrate past the sealing sleeve blowing back onto the tappet block.
in the pic I attached the hole mark red I understand this is tappet guide drain channel
Is that the only hole????
http://xlforum.net/forums/showthread.php?t=1379395
Hippysmack's Avatar
Per the SP page, some guides have one channel, some two, and there are some that have a spiral.
The groove in the SP pic (and your second link) is stopped up - can't see thru the oil.
Here is a Jims 1 groove tappet block.
