0 Do not buy this oil!
0 Ironhead Exhaust Poll
0 Issues with progressive springs
Last Post: XL1275
0 Shock search is OVER !!!
Last Post: XL1275
Last Post: Heff
0 Oil leaking
Last Post: Zari
Last Post: thefrenchowl
0 excellent color
0 top end rebuild
Last Post: eisenhead
0 Vulcan Mid Glide Triple Tree Conversion Set
Last Post: motorfish
0 Sportster 48 in a Nighster
0 Clutch blow up
Last Post: Tonimacaroni
0 New oil tank
0 weight loss thread
Last Post: catpepper
0 Fork seal follow up...Stop me if I'm being stupid.
Last Post: 1200CustomHD
0 my daily driver
Last Post: 84rzv500r
0 my sunday driver...
0 compression test question
0 Cruising RPMs
14 Buell back in business?
seajay, Hugh Betcha (74), jimhd89 (71), JayFL459 (71), Big Al (64), dakota_dj (63), 10walt (61), kiltbill (61), timsvalk (60), horsewriter (55), Benetampa (43), hobson8494 (36), Joker8494 (36), 8ball (31)
exhaust, fuel mix, popping, stumbling
Old 2 Weeks Ago
firevf06 firevf06 is offline
Sportster/Buell Model: XLX 61
Sportster/Buell Year: 1984
firevf06 is an unknown quantity at this point
Originally Posted by Ferrous Head View Post
So, in neutral, if you just slowly increase the revs it's OK ?
Is that correct ?
Does this happen at idle or only when you twist the throttle ?
Lack of power when your riding the bike MIGHT NOT BE the carb.
In neutral if you just barely barely turn the throttle it will act like no fuel but it is a very small window for that in neutral. it only causes fire when you turn the throttle. also, when i shut the bike off it kept trying to run and was sputtering and coughing for several seconds. It had this fall on its face problem when i first got the bike but i adjusted the 2 screws and it cleared up for a couple weeks. I'm wondering if the intermediate tube got plugged?
Old 2 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Sanity check time.
Do a compression test.
If that's OK. Check the ignition timing.
Then go back to the carb.
Here's a quick carb sanity check.
Buy one of the cheap S&S "Fake" Chinese carbs off Ebay. If you order one for an XLX 61 it will come jetted for your bike. Don't play with anything on that carb, just install it.
If that fixed your problem, either throw the Bendix where ever you want to and keep the Fake S&S or replace it with the Kehien and trouble shoot it leaving the S&S for future tests.
The "Fake" S&S Shorty E is like $59. It's a very cheap tool that works extremely well. You could just buy that first and skip testing compression and ignition timing.
If your pretty sure it's that carb causing the problem.
Old 2 Weeks Ago
Sanity check time.
I was wondering about checking the timing but I'm not sure how to on a motorcycle. It probably tells me in the book I have so will have to check. There is a shop down the road that works on old bikes and they told me they've had similar issues like this where they just bought a cheap knock off from ebay and that fixed it lol.
Old 2 Weeks Ago
doodah man's Avatar
You'll need to remove the small round cover on the cam cover to see just what ignition you are working with then we can help you out. Setting the timing is not a difficult job, but if someone changed the carb it's conceivable that it may not have the stock ignition any more either. Something else I would be adding to my check list is push rod adjustment, if you haven't already tended to it.
Old 2 Weeks Ago
I have not looked at the push rods yet. I will also have to read how to do that or check them. Is there a way to see if they need adjusted? Thanks
Old 2 Weeks Ago
Senior Master Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Can’t tune carb with faulty ign and out of spec compression/valve adjustment. Verify those first.
Battery voltage and connections are just as critical and could cause faulty carb like symptoms.
Old 2 Weeks Ago
doodah man's Avatar
Give this a read...
http://xlforum.net/forums/showthread.php?t=44143
Old 2 Weeks Ago
Blind Owl
Wait a second !
I thought this was an XLX ? Can't be much more than 40 years old.
I mean, it's go like Electronic Ignition and everything !
A late model thingy.
