0 stumble
Last Post: randy3934
0 Big bore Stroker problem
Last Post: Drewndtonic
0 Any Teamsters?
Last Post: Knuckles
0 Gear Spacing Question
0 New oil tank
Last Post: mikethebike61
2 My 1275 Hammer Conversion..
Last Post: Bryan1976
0 Bike wobble question
0 One More Ohio Meet & Eat?
0 Fyi
Last Post: salmanmr
5 Favourite grips?
0 Any wealthy forum members?
0 Stock vs. Modified
0 Forward controls
Last Post: jsandidge
0 too much oil in primary
0 Oil leak
0 1969 Shifter shaft bushing
Old 3 Weeks Ago
owlsplace owlsplace is offline
Sportster/Buell Model: XLH 1000cc
Sportster/Buell Year: 1981
owlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud of
Default Mikuni VM-38 bogs in cool weather
Finally got a couple rides in this year after putting on a lot of new parts: genset, rear wheel, reverted to stock sprocket ratio, shocks, swingarm bearings, exhaust system.
Last ride in cool temps (60s) the engine starting bogging a lot and the only way it would run was to leave the enricher on. It generally runs too rich as it is. The cams may not be stock on this engine.
I put the SUDCO Mikuni kit on last year. It did bog a bit on occasion but nothing like it does currently.
Any ideas? Float set too low? Plugged passage way?
I'm thinking the engine should operate down to freezing temps without bogging issues, especially after riding 20-miles. I need it to operate reliably into the 50-degree range.
Roger
Sent from my SM-G970U1 using Tapatalk
Old 3 Weeks Ago
Put it back to the VM38-9 spec and see what that does.
Old 3 Weeks Ago
I'm presuming you mean this spec that IronMick posted previously. See photo:
Old 3 Weeks Ago
doodah man's Avatar
What spark plugs are you using now?
Old 3 Weeks Ago
I think I put the 206 plug in last year with straight wires.
Drag Specialties Performance Spark Plugs - 2103-0206
Unique look plugs feature bold red logo/script and a black ceramic body
Available in the OEM heat ranges
Insulator is made of 95% pure alumina, features superior insulation and strong resistance to heat shock
Multi-rib insulator design eliminates flashover
Nickel-plated housing prevents oxidation and corrosion
Multi-layer gaskets and heat crimping process ensure a leak-free, gas-tight fit
Copper core electrode prevents oxidation and corrosion, has good electrical and heat conductivity and creates long spark plug service life
Sold in pairs
Old 3 Weeks Ago
billeuze's Avatar
billeuze billeuze is offline
Sportster/Buell Year: 80s
Other Motorcycle Year: 1983
billeuze has much to be proud ofbilleuze has much to be proud ofbilleuze has much to be proud ofbilleuze has much to be proud ofbilleuze has much to be proud ofbilleuze has much to be proud ofbilleuze has much to be proud ofbilleuze has much to be proud ofbilleuze has much to be proud ofbilleuze has much to be proud ofbilleuze has much to be proud of
I had the same symptom on my bike and it was resolved by replacing the ignition coil.
In cold weather would only run with the enrichment. I kept fouling plugs And would replace them about once a month with plugs 2 numbers hotter than stock. Finaly, bought a new coil and problem solved. Goes to show that just because doing something to the carb (using the enrichener) keeps it running, does not necesssrilly mean the carb is the source of the problem.
Old 3 Weeks Ago
I can see that happening but it is probably the last thing you would get to. I will do this.
I did swap out the main jet with the two spares that came with the kit without much of any difference.
Didn't notice any float bowl contamination.
Reminds me of the starting problem last year that drove me crazy. It turned out to be that nefarious loose battery connection that everyone tells you to check but you don't because it is in the back and you know you tightened it... sort of, maybe!
Over hill, over dale...
Old 3 Weeks Ago
GA_Ironhead GA_Ironhead is online now
Those are non-resistor plugs, according to the Dennis Kirk site: https://www.denniskirk.com/drag-spec...rd/2001033.sku
What does "straight wires" mean? Non-resistor? If so, you want resistor wires and plugs with electronic ignition.
How do stink bugs live with themselves?
Old 3 Weeks Ago
Should have mentioned this engine was reverted to points.
The appropriate coil is 5 ohms.
Wires are:
Accel Custom Stainless/Copper 8.8mm Yellow Spark Plug Wire Set - 172074
8.8mm size is rugged enough for any application
Yellow or black heavy-duty silicone wire sets
Fits terminal nut spark plug
Included Items:
(1) 20 1/2" plug wire with (1) Straight coil boot and (1) 90 degree plug boot
(1) 8" plug wire with (1) Straight coil boot and (1) 90 degree plug boot
Specifications
ColorYellowDiameter8.8 mmLength20 in. / 7 in.Mfg #:172074Part #:20341Size8.8 mmTypeSpark Plug Wire - CustomUnitsPairWeight0.43 lbs
Alternate/OEM Part Number(s):
162074
Old 3 Weeks Ago
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
This smells too much like an ignition problem. And (like thousands before you) you've found you can somewhat compensate for a f^#ked up ignition system by playing with the choke. In your case, enricher. Thus it has you thinking it's a carb problem. And maybe it is. But I doubt it. You know your ride. You're there. I'm not.
Often times there's more than 1 thing wrong. So where does one start ? Here's what I'd suggest:
  • stop messing with the carb
  • verify your ignition system is functioning correctly. If necessary, check all major components. At a minimum:
    • check / set your point gap. On both lobes. I suspect your point gap has closed up, but ??
    • when was the advance unit last serviced & lubricated ?
    • set your advance with a timing light
    • verify your advance is set at 40° BTDC.
  • test your ride again
  • what's your motor telling you now ?
Troubleshooting the next problem should go a lot easier knowing the ignition is properly set.
