0 Do not buy this oil!
0 Issues with progressive springs
Last Post: APJ CUSTOMS
0 Cam chest vent fitting
0 top end rebuild
0 Vulcan Mid Glide Triple Tree Conversion Set
Last Post: Dariusz
0 Sportster 48 in a Nighster
Last Post: Dariusz
0 Ironhead Exhaust Poll
0 Shock search is OVER !!!
Last Post: XL1275
Last Post: Heff
0 Oil leaking
Last Post: Zari
Last Post: thefrenchowl
0 excellent color
0 Clutch blow up
Last Post: Tonimacaroni
0 New oil tank
0 weight loss thread
Last Post: catpepper
0 Fork seal follow up...Stop me if I'm being stupid.
0 my daily driver
Last Post: 84rzv500r
0 my sunday driver...
0 compression test question
0 Cruising RPMs
Last Post: 1200CustomHD
seajay, Hugh Betcha (74), jimhd89 (71), JayFL459 (71), Big Al (64), dakota_dj (63), 10walt (61), kiltbill (61), timsvalk (60), horsewriter (55), Benetampa (43), hobson8494 (36), Joker8494 (36), 8ball (31)
  #161
Old 2 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Not easy getting images of small parts like this when your blind. Nut I am sure you can see what I mean.
Two things become apparant when I look at these pics.
Your cams have a very narrow "narrow" lobe compared to mine. Mine all have much wider open points. And this is sometimes a problem for me in actually picking the "narrow" lobe when I am doing my ignition timing.
I use Morris Magnetos and they have the best points and condensors you can get. But I really need to remember to put a drop of paint on my narrow lobes when I work them out.
Anyway, the second point is the timing points on your cam compared to mine is defiantly different.
What you need is a known good cam now to compare your with another one.
But I am sure your going to find a difference that will account for your timing issue.
Old 2 Weeks Ago
Blind Owl
Decreasing the width of the lobes is fine. But the opening point still needs to be at the same point.
With my lobes I can see the opening point is nowhere near the same as yours. And it's the opening point that counts.
If you look at the "narrow" lobe (the second pic) you can see my points would start opening at a point that is quite a few degrees before the beginning of the locating slot.
Now have a look at where your narrow lobe is opening the points in relation to that slot.
Old 2 Weeks Ago
owlsplace owlsplace is offline
Sportster/Buell Model: XLH 1000cc
Sportster/Buell Year: 1981
owlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud ofowlsplace has much to be proud of
Yep, definitely moving the break point in the right direction. That cam would probably work here.
Sent from my SM-G970U1 using Tapatalk
Old 2 Weeks Ago
Blind Owl
Find someone close by (if you can) that has a known good spare. Take yours for comparison.
But everything else checks out. "When you eliminate whatever is not possible whatever is left must be true."
