0 Big bore Stroker problem
0 New oil tank
0 Oil leaking
0 SE.536 cams, who has a set sitting around
0 Repainted my bike
0 XLCH chainguard
0 Done for now (no really)
Last Post: tizard
Last Post: chilly
Last Post: XL1275
0 One More Ohio Meet & Eat?
0 It's Glamazon's Birthday!
0 newbie
0 Gear Spacing Question
0 Strengthening 73 rear shock structure
Last Post: mikethebike61
0 FAF Sporties
Last Post: drgonzo21
0 Any wealthy forum members?
Last Post: 1200CustomHD
Last Post: Full-Bore12
0 30 tooth pulley? For ‘04-06
0 Rare As Hens Teeth? (Stock Parts Secondhand)
0 Disassemble tranny HELP
0 Reassemble engine
0 1991 Manifold Bolt Trivia (?)
Last Post: 45Brit
Old 2 Weeks Ago
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Shovel/Pan
Other Motorcycle Year: 1967
rivethog has disabled reputation
Originally Posted by mrmom9r View Post
Still waiting to learn how to put 6 gallons in a 5 gallon bucket.
Get a 5gal bucket from Canada or the UK?
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb socket genuine Aftermarket rear fender generic countershaft sprocket Radio Shack 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
Old 2 Weeks Ago
stikflote stikflote is offline
Sportster/Buell Model: sportster xlc
Sportster/Buell Model #2: xlh 1200 c
Sportster/Buell Year #2: 2005
Other Motorcycle Model: Triumph Kawasaki
Other Motorcycle Year: 2018
stikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud of
Our petrol is bought in litres buckets in litres so still cant 6 gallon in
Old 2 Weeks Ago
You can get those buckets from Blivet, Inc. Add 6 gallons and you'll have 4 gallons of room left!
How do stink bugs live with themselves?
Old 2 Weeks Ago
rivethog's Avatar
6US gals = 4.99605Imp gals. 5 Imp gal gas can?
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
I can get 70 litres of petrol into my 60 litre tank at my local gas station.
That's why I always go there. Everywhere else I can only fit 60 in.
I suspect the concerns about valve seat inserts stems from putting them in alloy heads. With the differences in expansion rates and heat transfer that's a totally different situation.
I suspect that getting someone like MrMom to do the seats would leave you with better performing ports than just cutting in wider seats.
Of course, that's just my opinion and I could be wrong.
Sportster/Buell Year: 1969
RicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud ofRicThompson has much to be proud of
I don't understand why anyone would be worried about having valve seats installed in an Ironhead. When done properly they will not fail. I think the number one benefit with having the valve properly located in the head is rocker arm geometry. I recently had all 4 seats in my 900 heads replaced. The only change I made was to install the larger diameter 1000 intake valve. Obviously it was also a great time to clean up the ports and do a little blending.
davixlrtt's Avatar
davixlrtt davixlrtt is offline
Sportster/Buell Model: 1965 xlch
Sportster/Buell Model #2: 1991 Honda XR600
Other Motorcycle Model: 1986 suzuki gsxr 750.
davixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant future
I would like to thank everyone who took the time to participate in this discussion and I appreciate everyone’s personal opinion and advice. I honestly think I’ll go with replacement seats and the correct valve size for my 65 XLCH. My next question is, do I supply the seats or do the cylinder head specialists have standard size blanks they keep in stock? I have seen seats advertised on eBay.
A really good And long established precision engineering shop which was local to me has now moved into a different line of business. They used to make and fit seats into the ATV machines I work with but now won’t touch anything automotive so I’ll have to find somewhere else.
So do you think the eBay seats would be something I should be looking into?
https://www.ebay.co.uk/itm/Harley-Sp...-/150879424656
.......Davi.
Nitro Frankie Toth did mine about 8 months ago. He provided the seats. Very pleased with the outcome. My 69 has 4 and 5/8's wheels, Sifton Titan cams. I've got about 800 miles on it now and it screams.
Blind Owl
It's generally not a good idea to supply parts for other people to fit.
The machinist may ask you to supply and in that case go ahead. But if you have someone experienced with doing this work they may prefer to source the parts themselves.
This also keeps the job simple in terms of what happens if something DOES go wrong down the track. If you were to have a failure, is it the machinists fault or did you supply bad parts ?
Ask your referred machinist first. Then go with what he wants.
Oh sorry. Just my opinion of course. Not telling anyone what to do.
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
Also be sure to provide your machinist with the factory valve height spec diagram so they can grind the seats just enough to reach the minimum height. This will allow future seat/valve dressing without exceeding the factory spec.
Eric
