0 Bike wobble question
0 One More Ohio Meet & Eat?
Last Post: Yakcm2
2 My 1275 Hammer Conversion..
0 Fyi
0 Gear Spacing Question
0 Any Teamsters?
Last Post: salmanmr
5 Favourite grips?
0 Any wealthy forum members?
0 Stock vs. Modified
0 New oil tank
0 Forward controls
Last Post: jsandidge
0 too much oil in primary
Last Post: randy3934
0 Oil leak
0 1969 Shifter shaft bushing
0 What Carb
Last Post: wachuko
Old 2 Weeks Ago
Hippysmack's Avatar
Default IH Crankcase Pressure and Engine Breathing
I've created a page in the Sportsterpedia for CC pressure and engine breathing.
Link is here: http://www.sportsterpedia.com/doku.p...:ref:engmech07
I figured laying it all out here as I've already done in the Evo section would be a lot of duplicated information.
This is a compilation of what I've been researching for quite a while now.
There are many, many sub documents lit up in blue.
These are all separate pages and all you have to do is click in the blue wording to open the page.
I tried to make the main page more digestible and used the sub docs for further information on certain topics.
This is a lot of information there.
I figure if it doesn't pertain to you, that's OK, but it may pertain to others.
I do realize there are facts as well as theory in this subject matter.
I'm completely open to questions, suggestions, critique or revisions.
This is for all of us and the information needs to be usable and follow-able.
So if there is any parts unclear, in error or needs more explanation, please say so.
It's not finished but I finally came up for air so I figured I go ahead and post what I've gotten done so far.
I'm still waiting for information on the pics for the 8ball breather and hoping to pick for more information as well.
Old 2 Weeks Ago
sportsterdoc's Avatar
sportsterdoc sportsterdoc is online now
Not yet absorbed it all, but you did a great job of organizing, with points succinct.
More reputation points to you...not that many folks are giving rep points recently.
Hippysmack's Avatar
Thanks sportsterdoc,
I'm doing this for mine and everybody's benefit.
A soon as I understand something new, I just forget it again.
So writing it down helps me too.... what was we talking about again.
My dad's brain was sharp right up to his death at 91...that is encouraging, but when I am doing multiple math calculations, if I don't write down the result of each step, I have to do it all over again...and that's only at age 73.
Hippysmack's Avatar
Heh, I'd be happy if I could remember what I did with that screwdriver I had a few minutes ago.
My dad built paper models. At his age, he was sharp with loads of attention to detail.
Built a rifle that looked very real at a distance and a small motorcycle all out of 8-1/2x 11 sheets of paper printed off and bent/glued.
My hands can't find tools when I just laid them down. Getting old sucks.
So, reading the piston sweep volume:
From MobilIndustrial.com
"Total piston sweep is a consideration in the determination of oil-feed rates for some reciproxcating compressor cylinders, and may be determined as length of stroke x cylinder circumference diameter x 2 x no. of cylinders x rpm x minutes of operation."
Does this formula correspond to your calculations?
Is the Mobil formula applicable for a V twin application?
Not challenging your calcs, just wondering.
My rollaway has a place for each tool, but back in the seventies, when I had three 4 barrel carbs strewn all over the garage floor, trying to make one good one, the tools would be strewn all over with the parts.
Where is that _____? I just had it. And that was half a century ago!
May not necessarily be age, but based upon focus.
Hold that thought and sleep well!
BTW, back when speed shops were abundant, especially in the San Fernando Valley of Los Angeles, parts for Holley carbs were easy to source, but I will take a Carter AFB over Holley any day.
mrmom9r's Avatar
mrmom9r mrmom9r is offline
The older I get , the more I think about the hereafter.
Every time I walk into a room I think " what am I here after?"
Hippysmack's Avatar
I did that today actually.
Went out to split the 77 foo-foo apart for pics and went back in the house for a .... still can't remember.
sportsterdoc,
That information actually came from Dr Dick. I haven't ran the numbers.
Sounds like he was talking total volume though.
The subject came up recently of blowby and an earlier question of mine on overall swept volume differences in the year models.
So I plan on expanding that page with calculations.
I believe cylinder swept volume is the volume 1 piston moves to make 1 stroke.
Total swept volume would be both pistons together.
All that changes with different bores and strokes.
And my question of what that does to the different breathers.
hippy always had an analytical mind!
that said, a member here has started me on a tangent project, even pulled it from the closet, an ole vega banjo.
my ? for mr. hippy is have you ever tuned your drums?
i am going to build my own drum dial gauge but looking for experience so as to know what to expect.
