0 2001 sportster oil line question
0 Do not buy this oil!
0 Issues with progressive springs
Last Post: APJ CUSTOMS
0 Cam chest vent fitting
0 top end rebuild
0 Vulcan Mid Glide Triple Tree Conversion Set
Last Post: Dariusz
0 Sportster 48 in a Nighster
Last Post: Dariusz
0 Ironhead Exhaust Poll
0 Shock search is OVER !!!
Last Post: XL1275
Last Post: Heff
0 Oil leaking
Last Post: Zari
Last Post: thefrenchowl
0 excellent color
0 Clutch blow up
Last Post: Tonimacaroni
0 New oil tank
0 weight loss thread
Last Post: catpepper
0 Fork seal follow up...Stop me if I'm being stupid.
0 my daily driver
Last Post: 84rzv500r
0 my sunday driver...
0 compression test question
seajay, Hugh Betcha (74), jimhd89 (71), JayFL459 (71), Big Al (64), dakota_dj (63), 10walt (61), kiltbill (61), timsvalk (60), horsewriter (55), Benetampa (43), hobson8494 (36), Joker8494 (36), 8ball (31)
Old 2 Weeks Ago
doodah man's Avatar
Awesome diagrams, thanks for taking the time to create them!
Old 2 Weeks Ago
Hippysmack's Avatar
Thanks doodah.
Just trying to get it done and right for the ages.
Old 2 Weeks Ago
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant future
Hippy,
All the figures quoted in that extract of your PDF are WRONG...
If the cams labelled XL (57/65 only, then P then Q) had such timing, the 57 XL would have gone 150mph if made to last...
Breather timing is wrong as well...
This delusional cam timing has been repeated in the factory FSMs over the years, at least since 1985 (my last year for on hand FSM and interest as far as Sportstser goes...)
The values I have quoted are right, you can check them with feeler gauges inserted into the breather tower while rotating the engine.
Another proof is that you can make an old tower like the post 72 tower by just enlarging the closing side of it and not touching the opening side. I've done that numerous times...
My last comment on this pressure/vaccum never ending palava... You all talk about "pressure" when the pistons go down. It would be "pressure" only if the oil fog in there had nowhere to go...
BUT, the breather or foofoo fighter opens as soon as maybe 1psi above A.P. (16PSI) is present, then the oil mist is PUSHED out to atmosphere.
You can test this on any Sportster: block the external pipe and start your engine. Stay well away as the oil mist will certainly and vengefully spew out of every joint face it can blow... THIS IS PRESSURE...
So, there is vaccum for sure, then air displacement, no pressure at all...
Just like Sportster oil pumps, once warm, no pressure to show, they just move oil around.
Lastly:
Hippy: 72-76 Opens 20°-25° (ATDC) and closes 85°-90° (ABDC).
What's the 5 degree lead in opening and closing?
Is that accounting for gear lash?
No, that's allowance for manufacturing tolerances. Like cams, usually at H-D, + or - 2 degrees.
Patrick
Flat Head Forever
Old 2 Weeks Ago
npaisnel npaisnel is offline
Sportster/Buell Model: XL883 now 1200
Sportster/Buell Year #2: 1993
npaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond reputenpaisnel has a reputation beyond repute
Originally Posted by sportsterdoc View Post
More reputation points to you...not that many folks are giving rep points recently.
I’ve been hear (XLF) a few years now...not a concept i have come across , or seen a link to give em to someone... wonder if this is a result of more people browsing and posting on phone rather than decent size screen
Old 2 Weeks Ago
harley506d's Avatar
Sportster/Buell Model: 1200c
In the Orange bar above the post, the middle one, scales.
Old 2 Weeks Ago
Ah ..never tried that before...or the Multi Quote button... Any multi quotes have done before...I did manually .
OK, sorry for Hijacking the thread with irrelevant stuff...
Mod can now delete these !
Old 2 Weeks Ago
Hippysmack's Avatar
That abstract of the PDF is the actual service bulletin.
That is interesting that you say it is wrong. I didn't know that.
But you could have told me sooner.......
I think I could mock up a pump to simulate installed and TDC to test with.
Just gotta afford the pump.
So you have measured this with a degree wheel?
If using a feeler gauge, you can tell when the two slots come together (open) but how do you know where the opposite end of the gear slot is in crank degrees?
I do realize you guys have been fooling with these pumps for a long time.
And this is going way past the service manual. So I think everybody can benefit from the knowledge.
I'll leave that 57 drawing as it is since that is the actual numbers from the bulletin.
There were no other TSBs issued to correct it. So it needs to be done regardless.
I'll get started on a drawing for the pre-72 numbers you provided also.
Yes, the tower can be cut and the gear can be cut to add duration.
I've been looking at the XR books regarding pump mods.
I remember hopper writing that a Z pattern has been cut before in the gear to add duration also.
I like the drawing as it helps visualize what is happening during the pressure cycle.
I want to make drawings up thru 85 so I can see the changes.
So I wanted the timing numbers to be accurate.
I have searched high and low and can't find timing specs for pre-72 pumps other than that service bulletin.
I scaled the pics of the pre-72 gears and I can't find any difference between the width of the window from 57-60 PNs.
So I am comfortable saying the timing being the same from 57-71.
I haven't noticed any difference in tower window size from the two either unless the pics I've been looking at aren't correct years.
I do understand air displacement. Same as this quote, downstroke displaces vacuum.
And that is what happens constantly and variably in the bottom end.
It may just be semantics but downstroke creates positive pressure.
That first reduces the vacuum and air pressure builds only after vacuum has been reversed.
Thank you for those dims needspeed.
Example 1.
If you were to blow into a sealed container and had only 1 second to do that before you had to inhale, all you would do is expand your cheeks.
You blew the same amount of air out that you inhaled, but kept it from leaving.
And then you have to inhale for 1 second.
(the pressure you created expanded your cheeks 2" in diameter, )
Example 2.
If you blow with the same pressure with an 1/8" hole drilled in the container, some air escapes out the hole.
(the pressure you created expanded your mouth 1" in diameter)
Example 3.
Now if you increase the hole to 1/4".
Blow with the same pressure and you get a full breath out.
(the pressure you created did not expand your cheeks)
In the first two examples above by the time upstroke happened, your still holding positive pressure in your cheeks.
Your cheeks represent the crankcase.
In the third example, you are holding more vacuum in the crankcase than before on upstroke.
Now add a negative differential (upstroke) to each example.
2" upstroke = 2" downstroke.
Example 1.
2" of positive (what's in your cheeks) minus 2" of negative (inhale) yields a pressure of (0, atmosphere) in the crankcase.
Example 2.
1" of positive minus 2" of negative yields a pressure of (-1 vacuum) in the crankcase.
Example 3.
0" of positive minus 2" of negative yields a pressere of (-2 vacuum) in the crankcase.
Old 2 Weeks Ago
''no good deed goe's unpunished'' i was just reminded of where i saw that here in another thread.(Georgia)
Old 2 Weeks Ago
Hippysmack's Avatar
Ain't it the truuuff..
Ok, how's this?
Old 2 Weeks Ago
mrmom9r's Avatar
mrmom9r mrmom9r is offline
Closes 85-90 degrees ABDC
You're half way there
