0 Gear Spacing Question
0 New oil tank
Last Post: mikethebike61
0 Big bore Stroker problem
2 My 1275 Hammer Conversion..
Last Post: Bryan1976
0 Bike wobble question
0 One More Ohio Meet & Eat?
0 Fyi
0 Any Teamsters?
Last Post: salmanmr
5 Favourite grips?
0 Any wealthy forum members?
0 Stock vs. Modified
0 Forward controls
Last Post: jsandidge
0 too much oil in primary
Last Post: randy3934
0 Oil leak
0 1969 Shifter shaft bushing
0 What Carb
Beary Beary is offline
Beary is an unknown quantity at this point
Default 1 step forward, 3steps back XLC
I’m trying to get bike in a condition I can start it.
1 step farward - pulled the plugs, shift to 4th gear and the engine turns.
1 step back - Tried to bolt Battery box to oil tank and the tank threads are stripped.
2nd step back - Tried to bolt oil tank/battery box bracket to transmission case and found the case threads are stripped. I’m not sure if your supposed to see the gears, but you can. Threads are really more than stripped, the bolts are VERY loose in the holes.
3rd step back - pulled the metal tape from the points cover and found a piece of the case on top of where the points cover goes the size of a quarter broke off.
Ok, there are other issue, but these are my discoveries today.
Is the motor worth trying to save compared to just the cost of fixing the holes on the transmission case and cam cover?
I can tap larger hole in the oil tank, but what the fix for the tranny case?
I’m still going to try firing up the engine just to make sure I have something worth an effort. But I haven’t even approached the S & S carb yet.
Beary
Beary
doodah man's Avatar
I will say, it's normal that the case bolts open into the trans cavity. You can carefully drill/tap those to the next size, and if they go through the motor mount too be sure every thing ends up centered. Best practice is to remove the trans to keep it clean and free of aluminum chips/shavings. Also very important, choose replacement bolts that aren't so long as to come into contact with the gears below.
1Scooter 1Scooter is offline
Sportster/Buell Model #2: 2004 XLH1200Custom
Other Motorcycle Model: 2007 FXDB
1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold
Don't be discouraged. These old Irons have taken a beating from previous owners and time has taken it's toll. Doodah man nailed it. If ya can't drill oversize and re-tap it, there's always Heli-coils. LOL, I have quite a few different sizes left over from my 77 restoration/rebuild.
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
You list it as an XLC.
If it REALLY is an XLC then yes, whatever you do would be worth it.
The XLC is sort of a mythical beast. Offered for sale by HD but it appears they never sold one. (I might be wrong on that)
The XLC is the low compression version of the factory Hot Rod, the XLCH. Why on earth would anyone buy a low compression version of a Hot Rod ?
Possibly Harley thought it would make a good 6 Days Trial mount.
Does the VIN say something like 59XLC ?
randy3934's Avatar
randy3934 randy3934 is online now
thought it was a 73 xlh?
Blind Owl
That was at the top of the first post.
Whoops, sorry, long day. XLH.
Nitro57xl Nitro57xl is offline
Nitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of lightNitro57xl is a glorious beacon of light
Please don't drill & tap to the next bigger size? Fix it right! Helicoil the original holes. Use original size bolts.This isn't farm equipment we are working on here, don't butcher it up?
What’s it going to take to fix the holes in the transmission without getting debris in there?
Beary
Blind Owl
Here's where your in luck.
The Sportster engine has what's known as a "cassette style" gearbox. The gearbox can be removed without splitting the cases.
Granted, you have to pull the primary drive and clutch but if you have ever worked on a typical Japanese 4 cylinder engine with horizontally split cases you'll see the benefits.
There is going to be some small amount of debris in there already. It might not be much and it depends on just how good a job you want to do.
because of the location it's going to be awkward at best to drill this and put a heli in. You might need a right angle drive drill - I don't know, I've never attempted an in situ repair there.
But also, this damage is indicative of someone who wasn't all that fussed about looking after this bike. I would suspect you may find a fair bit of damage or at least maintenance required elsewhere.
I suspect this is a candidate for engine out and on the bench work. At the very least you need to do a full survey of what you have.
