0 91 883 sporty died while riding, will not crank.
0 Supertech oil filter cross refetence
Last Post: AZbiker
0 WTD: XL1200S SE Ignition module
Last Post: flak monkey
Last Post: Blowupster
0 How Indian Makes 43% More Power than Harley-Davidson
0 Ironhead 1984 trouble shooting
Last Post: Vasiliy
0 What Carb
0 Air Filter / Fuel Filter on a 2005 XL1200C
0 FS: Mustang Fastback 96-03 Sportster
0 Newbie Question. (Years With Least Electronics?)
Last Post: farmall
0 Speedometer upgrades
0 'Sportster poster
Last Post: 1200CustomHD
0 Deserted '07 Harley Sportster 1200 Custom
0 Oil leak
0 Points Assembly - Circuit Breaker Cam and Alignment Pins
0 Sportsterpedia Progress
0 1969 Shifter shaft bushing
Last Post: Doc308
0 Help with oil pump drive gear
Last Post: tizard
0 Help! Clutch cable replacement
Last Post: Hellbent_4
0 1981 Ironhead Dual disk question
0 New sportster in HD Research Survey
0 Sportster Seat For Sale
Last Post: XM381
0 Fyi
0 80 sportster coil replacement ohms questions
Last Post: blk80bike
0 XLFORUM quit smoking thread
Last Post: XL1275
0 Replace sprocket
  #31
Old 3 Days Ago
Beary Beary is offline
Beary is an unknown quantity at this point
Originally Posted by Ferrous Head View Post
You don't need "expert" Harley mechanics. Think of this engine as a 350 Chevy engine from a 1969 Camaro. Now, could you find people to help you with that 350 ?
Those people will recognize everything inside your engine other than the clutch.
The FSM and parts manual will tell you everything else you need to know.
Document it with pics as you go,. Before and after. Everything.
Probably right. The basic's don't concern me, it's basically like an airplane or car engine. The cams seem a pain.
I'm not worrying about the front brake now because I would really like to replace this rusted mess with a smaller lighter caliper. I don't mind these forks, but I understand they may have to go just to get a different caliper. Rear brake appears OK, EXCEPT, the pedal spring is attached to the pull rod on the right side. Works OK, but not stock.
The wiring is rotting and really a mess. A push button is wired to a mechanical push button starter relay. I'm not understanding that. The only thing that keeps the wiring somewhat simple is that there is no other wiring. LOL.
Anyways, lots of adventures.
Beary
Old 3 Days Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
That's OK. I only have five wires on my Sidecar. One to each plug (4) and one ground wire.
