0 How Indian Makes 43% More Power than Harley-Davidson
0 91 883 sporty died while riding, will not crank.
0 Supertech oil filter cross refetence
Last Post: AZbiker
0 WTD: XL1200S SE Ignition module
Last Post: flak monkey
Last Post: Blowupster
0 Ironhead 1984 trouble shooting
Last Post: Vasiliy
0 What Carb
0 Air Filter / Fuel Filter on a 2005 XL1200C
0 FS: Mustang Fastback 96-03 Sportster
0 Newbie Question. (Years With Least Electronics?)
Last Post: farmall
0 Speedometer upgrades
0 'Sportster poster
Last Post: 1200CustomHD
0 Deserted '07 Harley Sportster 1200 Custom
0 Oil leak
0 Points Assembly - Circuit Breaker Cam and Alignment Pins
0 Sportsterpedia Progress
0 1969 Shifter shaft bushing
Last Post: Doc308
0 Help with oil pump drive gear
Last Post: tizard
0 Help! Clutch cable replacement
Last Post: Hellbent_4
0 1981 Ironhead Dual disk question
0 New sportster in HD Research Survey
0 Sportster Seat For Sale
Last Post: XM381
0 Fyi
0 80 sportster coil replacement ohms questions
Last Post: blk80bike
0 XLFORUM quit smoking thread
Last Post: XL1275
Old 3 Days Ago
randy3934's Avatar
remove sprocket cover, may need to remove rear exhaust to accomplish this, mount indicator and measure end play at shaft end "IN OUT" record the measurement for future use, and check for radial play or runout, "UP DOWN SIDE TO SIDE" this will indicate mainshaft roller and race condition.
Old 1 Day Ago
Beary Beary is offline
Beary is an unknown quantity at this point
I’m getting pumped to do this, but Im still not sure how to repair the holes. They are so rounded out that I don’t think a hilacoil is made that will fit. I’m tempted to tap a hole for a larger bolt that fits and then tap that bolt for the stock bolt. I need the opinions of a machinist.
Beary
The other bolt in the picture is the stock bolt sitting very loosely in hole to keep debris from falling in the gears.
Old 1 Day Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
I've been doing heli-coils and keenserts for years.
But for my race engines I call a mate you has a mobile thread repair business. That's all he does. And he can fix anything that needs a thread.
Google businesses in your local are and you may find some one like that.
Not as expensive as it might seem at first sight. You can buy "Bigserts" that will probably do the job. But you'll need a "kit" to start with that has the required tools.
For just two holes it may be cheaper to pay a professional.
http://www.timesert.com/html/bigsert.html
Old 1 Day Ago
Yes, I looked for the timesert size I need and couldn’t find one. I like the idea of a professional. Once and done. That’s why I was thinking machinist, but I will look for a timesert specialist.
Old 1 Day Ago
Blind Owl
I use professionals for things that matter. I can weld, I can machine, I can do a lot of things.
But there are people ho do these things over and over every day for a living.
I cannot match their expertise.
I do the things I do and let the experts do the things they do.
Old 20 Hours Ago
I found this discussion on the XLFORUM during my search. Something I had never heard of was the twinsert. That would be a helicoil solution to my problem, but the Keensert appears to be the best solution since the hole is so big.
http://xlforum.net/forums/showthread.php?t=1701138
