0 Cruising RPMs
Last Post: 1200CustomHD
0 Rare As Hens Teeth? (Stock Parts Secondhand)
3 Wtb, Wts, Wtt, Wtg (EFIs)
Last Post: toomuchstuff
0 XLCH chainguard
0 Big bore Stroker problem
0 New oil tank
0 Oil leaking
0 SE.536 cams, who has a set sitting around
0 Repainted my bike
0 Done for now (no really)
Last Post: tizard
Last Post: chilly
0 One More Ohio Meet & Eat?
0 It's Glamazon's Birthday!
0 newbie
0 Gear Spacing Question
0 Strengthening 73 rear shock structure
Last Post: mikethebike61
0 FAF Sporties
Last Post: drgonzo21
0 Any wealthy forum members?
Last Post: Full-Bore12
Gold Member's Avatar
Sportster/Buell Year: 1972
Default wheel truing stand
My PO put a brand spanking new Dunlop Harley tire on a severely bent rim. I'm getting a new rim and spokes for it.
What stand do you guys recommend?
Stop by my build thread:
i used a pair of jack stands for underneath a car.you can also use the front forks of your motorcycle.cost for that is zero.
Tim The Grim's Avatar
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 97
I use my old KHK swingarm in a vise, with my magnetic indicator holder on the flat.
Old 6 Days Ago
harbor freight has a stand that if beefed up will work, originally for balancing.
what i do is a rod or long bolt for the axle and pvc pipe as spacers and a good vise. you will need two indicators or old school feelers. minimize axle play and you are good to go.
Old 6 Days Ago
Thanks guys I do have a couple of jack stands. PVC pipe spacers is a good idea.
Growing up I was coasting downhill with one of the neighborhood kids and the front wheel on his brand-new Schwinn collapsed from loose spokes. The kid got all effed up. So I have a lot of fear and respect for spoke wheels
Old 6 Days Ago
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
I like to true them in the forks or swingarm. Holds it solid and makes it easy to keep the rim in the right place laterally.
