2 My 1275 Hammer Conversion..
Last Post: Bryan1976
Last Post: mikethebike61
0 Bike wobble question
0 One More Ohio Meet & Eat?
Last Post: Yakcm2
0 Fyi
0 Gear Spacing Question
0 Any Teamsters?
Last Post: salmanmr
5 Favourite grips?
0 Any wealthy forum members?
0 Stock vs. Modified
0 New oil tank
0 Forward controls
Last Post: jsandidge
0 too much oil in primary
Last Post: randy3934
0 Oil leak
0 1969 Shifter shaft bushing
0 What Carb
Last Post: wachuko
Old 5 Days Ago
73HEAD 73HEAD is offline
Sportster/Buell Year: 1973
73HEAD is an unknown quantity at this point
Default too much oil in primary
hi people, i think i might have a serious problem?? i filled up the primary the other day and somehow, ( i dont know why) but i filled the primary to the brim. idiot!!! The bike started idled for a short time and conked out i noticed oil coming out of the clutch adjustment port. SHIT!! Ilet it be and drained the oil to where it should be. left the fluid level allen key out and left it for a few days.
now when i try to start it there is an almighty clang type noise coming from the primary as i hit the start button. so i have left it and will get to it over the next few weeks. any idea what sort of damage i may have done. thanks.. the bike is a late 73 xlh.
you dont have to have a long neck to be a goose.
Old 5 Days Ago
sportsterdoc's Avatar
Did you drain, then refill with proper amount?
Do not know about ironheads, but EVO is 28 ounces.
Old 5 Days Ago
randy3934's Avatar
remove the oil level screw "somewhere around the left footpeg mount" block the bike up level, when it stops draining you have the correct amount in there, 73 has the bypass valve so you use the same oil in primary as engine, this bypass valve will allow excess oil to flow between primary and crankcase, if you put that much oil in there you should pull the timing plug and spark plugs and crank it over till it quits barfing oil out the timing plug hole.
Old 5 Days Ago
randy3934's Avatar
had one brought to me that the guy said was siezed up, musta had 5 qts of oil in the primary, drained it to fill level screw, removed timing plug, oil came pouring out, engine was hydro locked, cranked engine till it quit coming out and it was happy again.
Old 5 Days Ago
Senior Master Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Compensator loose?
Old 4 Days Ago
hey randy, yes i pulled oil level plug a few days ago and let it find its way out. the clutch would probably be gummed up now so im going to pull the primary off soon. but what concerns me is the horrible noise it makes when hitting the start button. its sort of like a clunk bang thud all at once as though something inside has come off or brokenits back at the right level now but the noise frightens me. so i suppose i should have a good look inside the primary before i do anything?. thanks for getting back to me
Old 4 Days Ago
yes sportsterdoc. ironheads i am learning as i go along. i have a parts manual and a service manual from the factory. i dont know why i filled it up so much. i reall dont. thanks for getting back to me
Old 4 Days Ago
ill pull the primary off soon and have a squizz. i intended to anyway soon. would something like the compensator just come loose? ill have a good look. do i need to worry that oil might have gotten in to places that it shouldnt have? thank mate
Old 4 Days Ago
randy3934's Avatar
if the crankcase is hydro locked it'll make some serious banging noises and probably won't turn over.
Old 4 Days Ago
whats a hydro lock? how do i fix it if thats the problem?
