0 Chasing a generator noise
Last Post: DR DICK
0 Installing jugs finally but another Q
0 55* this morning
0 Sifton cams on stock 74 XLCH
Last Post: DR DICK
0 Arlen Ness F-Bomb Pipe Test
0 2007 883R From Sunny Old England!
0 Pinion shaft holder tool
0 Better Brakes
0 Do you like Mexican food?
0 Covered shocks
Last Post: Heff
0 Xlh 883 oil tank paint
0 starting rollers
0 Potato-potato
6 1983 Ironhead- Final wiring
Last Post: Attaxic
0 is a buell a harley
0 Tools
Last Post: Eric Von Zipper
0 77xl sportster
0 XR750 resurrecting
0 Microsquirt EFI Conversion
0 KBS tank sealer
Last Post: Len PA
Last Post: Reverend G
lineberger, 39dan (62), FstPig (61), jmdajd (57), ironhead 74 (57), erjasn84, Bada Bing (56), ottchuck (55), OutlawTexan67 (53), RAJ (47), Wintersdark (44), robychopper (44), TnsporT (43), MotoSquirrel (36)
Old 14th October 2020
dono57 dono57 is offline
Sportster/Buell Model: XL883L
dono57 is an unknown quantity at this point
Mine were finger tight when I went to remove them to pull the rear wheel @15,000mi (2008 883L )
I'd noticed an intermittent whoop,whoop sound but being my 1st Harley and the Sure Shot pipes, I wasn't sure if this was normal. Guess I found the source!
Old 23rd October 2020
Sportster/Buell Model: XLH883
I lost one nut on my rear pipe after I replaced the entire exhaust system. So, I replaced the nut and kept an eye on it for some miles, no more issues since then. Don't know if thread lock is advised.
XL1275 XL1275 is offline
XL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant future
Key is to retighten after a few heat cycles as the gaskets seats. Only thread locker that would come close is red loctite and it's probably not going to work either. Even if it did work, breaking off a stud in the head is no way to live life.
I checked mine after the latest round of removing the pipes and 600 miles. Still tight. Never hurts to check every so often.
Old 24th October 2020
mlan12 mlan12 is offline
mlan12 has much to be proud ofmlan12 has much to be proud ofmlan12 has much to be proud ofmlan12 has much to be proud ofmlan12 has much to be proud ofmlan12 has much to be proud ofmlan12 has much to be proud ofmlan12 has much to be proud ofmlan12 has much to be proud ofmlan12 has much to be proud ofmlan12 has much to be proud of
I have not had a problem with the nuts since the last installation. While tightening the nuts I tightened them until they were very snug. Then with a very small hammer I gently tapped the flange the nuts screw down on to. Each time I tapped the nuts would turn another one to one and a half turns. This procedure was repeated about four times until the nuts were tight. As a precaution, after a few short rides, I added jam nuts.
