0 Black Bike Bible
Last Post: grako122
0 Rattling noise
Last Post: spacecoast
Last Post: gravydog
0 Why do sportsters look small?
0 How does it feel?
0 Rubber mount questions.
Last Post: Gazotenekes
0 How many helmets?
0 Mag Wheel Valve Stem Hole
Last Post: RKN
Last Post: Moon Wolf
Last Post: kopbilly1
0 Titanium Retainers
Last Post: Cropduster
10 Greetings from upstate NY
5 Other Bars instead of Buckhorns?
Last Post: sleighcrane
0 Mid glide
Last Post: cazz1000
Last Post: cotton1
0 carb pop on acceleration from stop
3 Possible ignition module going bad again and throwing timing off...
Last Post: groovemeisterus
0 main shaft leak
0 My next trip - AMA Vintage Motorcycle Days in Lexington OH
0 The forum got talent
0 Illium Works Versatile Highway Pegs Review
Last Post: MotoMoshe
0 THE Trainspotting Thread
0 Range With EFI 2.1 Gal Tank
Last Post: jammantoo
0 Craigslist?
Last Post: koolbreeze
NedNimrod, jduffy01, AlanT (70), jzink0883 (69), LVBOATDOC (66), glef (61), Dogsbd (56), darkcustom (41), jon8641 (34)
Old 11th June 2012
1250IRON's Avatar
1250IRON 1250IRON is offline
Sportster/Buell Model: Iron
1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light
Default Help With A Honda
I know this isn't a question about Sportsters, but I know someone has the answer to this. Please help if you can. My friend from work picked up a 1983 honda shadow that runs good, but he has a hard time starting it. it has an enricher and i don't know if this is different from a choke? seems to start really hard when shut off hot then try to restart it. doesn't matter if he just turns it over, puts on the enricher or holds the throttle open. just turns over and over then suddenly it will start if his battery doesn't die first. really sucks when we go for a ride and have to monkey with it to get it running every time it is shut off. it runs awesome once we're riding. do you use the enricher the same way as a choke? Where should he look to solve this? Thanks everyone.
2009 Iron 1250 Kit Stage 2 Light 883 Heads 497 Cams RB LSR 2 into 1 Thundermax Ecm
Old 11th June 2012
sportsterdoc's Avatar
Other Motorcycle Model: Honda CB1100
Other Motorcycle Year: 2014
Enrichener is what we have on carbed EVO Sportsters. It adds fuel, whereas a choke has a butterfly to block air flow.
Hard starting hot may be too rich idle circuit, float level too high, float level not quite shutting off (debris in float valve)...that is where I would start.
I've had 7 Hondas and 3 Yamahas, as well as 2 Sportsters, but the issues are very much the same.
Old 11th June 2012
Before tearing into the carb, be sure that his plugs look good, with good spark.
Old 11th June 2012
1250IRON's Avatar
Thanks guys. I have suggested he run some sea foam first and see what happens. I really hate working on dual carb bikes as i don't know much about carbs and synchronizing them.
Old 11th June 2012
Don't be concerned about carb sync. I've had one 4 carb bike and 5 dual carb bikes (3 were CV)...never an issue. For normal street use, just adjust the cables so all the carbs start to move at the same time.
Old 11th June 2012
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Syncro should not be an issue, bad battery or neg lead from the battery might.
Those are Keihin CV carbs and are generally very good from factory....check to see if someone has pulled the epa plugs for the low speed air jet. It was needed back then to get any kind of start and off idle performance.
Old 12th June 2012
1250IRON's Avatar
Great info guys! thanks. i'll pass all of it on to him.
Old 12th June 2012
Loner's Avatar
Loner Loner is offline
Sportster/Buell Model: XL883N
Sportster/Buell Year: 2012
Loner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant future
like any bike start with the basics, like Ireeman said check the cables, my 92 sporty had a bad ground cable and it would do the same thing run fine then start, then shut down, run, the dealerships Tucson and Phoenix couldn't find the problem and I took it the dealership in my hometown, this was 92 when it was new and the tech who had 20 plus years of experience, had it fixed before I got to my parents house where I was staying.
Hondas are usually good runners, but an almost thirty year old bike is bound to have some worn or corroded parts.
"I don't photograph in Black & White because I'm artistic, I'm colored blind"- unkown.
Old 12th June 2012
JasonSarratt's Avatar
JasonSarratt JasonSarratt is offline
Sportster/Buell Model: Turbo XL Sidecar
JasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud of
They have a good rep for having the starter solenoid/main relay not work when they are old and get hot...
Sent from my LG-P999 using Tapatalk 2
Old 12th June 2012
do basics. check for a clean firing via a timing light or some inline spark testers. once you know that the ign is not dropping on you, the run compression/leakage test. there is nothing that can help low compression short of a proper repair. if that is in order, then look at the fuel sys. that said, is this machine gravity as some hondas like the ace shadows and others use a fuel pump.
