Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Era Specific and Model Specific > XR Sportster Motorcycle Talk - XR750, XR1000, XR1200
XR Sportster Motorcycle Talk - XR750, XR1000, XR1200 For XR Sportsters: XR750, XR1000, XR1200
0 1970 XLH Tach cable kinked
0 S&S Super B help
Last Post: Gravitas
0 Iron 1966 XLRTT
Last Post: thefrenchowl
0 Swing arm bearing change
Last Post: SportsterXLCH1967
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
0 Canadians for sturgis 2021
Last Post: mikethebike61
0 WTB 04-06 intake manifold
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
0 RIP Trainman
Last Post: Randy_rots
Old 4th September 2019
Scott Scott is offline
Sportster/Buell Year: 1981
Sportster/Buell Model #2: Sportster with sidecar
Other Motorcycle Year: 2002
Default In search of XR1000 parts
I realize this section doesn’t have a lot of activity, but I’m hoping it still gets checked by people. I am building an XL/XR mongrel and need some high compression pistons, new or used (but useable). I also need a set of cams in a grind other than the stock Q. Again, these can be new or used. I realize new cams can be found, but I’m checking to see if anyone has a set gathering dust in a milk crate. I’m not a cheapskate; I’m just trying to finish this project before my budget dries up.
I have some XR stuff that might be worth something in swap to the right person. Thanks!
Old 19th November 2020
mwcjc mwcjc is offline
Sportster/Buell Year: 1966
mwcjc is an unknown quantity at this point
Default Xr1000
I have a set of harley factory E cams, racing pistons std with less than 600 miles on them also mikuni 42 mm flatside carbs with intakes that came in a kit from Jerry Branch Charles charlesjchesser@gmail.com
Old 23rd November 2020
84rzv500r 84rzv500r is offline
Sportster/Buell Model: XLH 1200 S
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 83
Other Motorcycle Model: RZV500R/R1 hybrid
Other Motorcycle Year: 1984
84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future
email sent
1999 1200 Sport, SE 7500 ignition, SE air filter, DynoJet , Cone Engineering 2:1 pipe, Storz Steering damper, Russel Mach 3 Stainless Lines, VROD 4 piston front calipers, Bates Baja tires, XR1200 perf shocks, forks and triples coming very soon...
1983 XR-1000S to XR-1000RX Project Build Thread
