0 Howdy from Baytown, TX
Last Post: jharback
0 Building a dragbike 101
Last Post: the cowboy way
0 How stock is your bike
Last Post: SLW210
0 Mixture screw has no effect. Need help!
Last Post: Big Al
0 Have I got my cam gears lined up right?
0 IronHead Wire Diagrams Etc
0 modifying to metal oil tank.
Last Post: Grumpy-Biker
0 Who's still riding???
Last Post: dodgetrucken
0 Seat Poll - Bad Ass or Fat Ass
0 Memphis Shades Rio Grande & Trigger Lock
Last Post: jswhite
14 How To: View HD Part #'s 1991-2010 - All Models - With Part #'s and Exploded Views!!
6 Is Your SPORTSTER...
Last Post: Sportycus
5 Your stomping grounds
0 To lay it down or not?
0 How many amps does a 2003 XB charging system create?
0 Spokes and dual disc
Last Post: PetesPonies
Last Post: rubine
Last Post: Jollly Rogers
Last Post: ed_in_az
0 When Were You Born?
Last Post: MacSporty02
0 Cracked exhaust bracket short shots
Last Post: newroadster
0 Early/Late 73 case date code
0 seat bolt
0 Gravydog crashed again.
Last Post: gravydog
Last Post: rubine
Joe in Mo Joe in Mo is offline
Joe in Mo is an unknown quantity at this point
Default 2004 custom (Cams)
new here 2004 sportster custom mikuni carb and Santini(?) shorty pipes has anyone done cams on these?want something bolt in that works from 0 to rev limit and need to know it the cranktrigger timing is a problem then? hope to learn a lot here!!!
wongjohnson wongjohnson is offline
Sportster/Buell Year: 06
wongjohnson is a name known to allwongjohnson is a name known to allwongjohnson is a name known to allwongjohnson is a name known to allwongjohnson is a name known to allwongjohnson is a name known to allwongjohnson is a name known to allwongjohnson is a name known to allwongjohnson is a name known to allwongjohnson is a name known to allwongjohnson is a name known to all
Welcome. I heard jackhammers from hammer performance is bolt in and mid range. But it's over 3 bills for'em. I personally got N8's from Andrew. I like'em, at 4k, they pick up. Start reading what makes a cam the way it is. Best of luck and ask, ask, ask here.
thanks,need all help I can get!
1Scooter 1Scooter is offline
1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about1Scooter has a spectacular aura about
When choosing a cam, ya gotta get one the fits what you expect from it. Bar hopper, stop light racer, super slab flyer, what rpm do you want MORE POWER???? No cam out there will do everything, like 0 to redline. Do some thinking on what you want, realistically. In the mean time do a simple upgrade to wake that 04 up. Start out with something like a Dyna TC-88 ignition unit. Simple plug n play. Just did one on my Wife's 04 1200 Custom. Set it for curve A (most aggressive,) and a 6500 rev limit. It hauls ass! Now I gotta get a 105 big bore kit in my 07 Dyna . . . to keep up with her. Then start thinking about internal engine changes. Basically, it's the KISS philosophy, KEEP IT SIMPLE.
rocketmangb's Avatar
570'S From Hammer Performance
Decent exhaust
Good air cleaner
TC88A from Daytona
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
rejeanprimeau's Avatar
The Hammer 570 are like the W, stock in 1200 but not in 883; D cams.
The SE 495 are a good bolt in cam that will wake that 1200. Higher than those, you'll need head work.
Default 570
570'S are worth about 10 HP over the W grind
