0 Hard saddle bags -
Last Post: Samedward
Last Post: Cablejudge
Last Post: XL1275
Last Post: ReddTigger
Last Post: class of 82
0 "S" model specific Q&A
Last Post: ftwflh
Last Post: XL Dane
4 What will 10 cents buy?
Last Post: Iron Chuck
Last Post: DollarBil
Last Post: Proteus
Last Post: soundnav
0 Swapping out single speedo for 1200 dual gauge setup
0 HTML Code
0 AGM battery for 76' XLH
Last Post: The Doctor71
Last Post: sprink
PlanB, Cuco6924 (74), 1200sporty (63), iron68 (49), LifesHarlequin (36), mattosm (35)
Old 10th August 2020
soundnav soundnav is offline
Sportster/Buell Year: 1972
Sportster/Buell Year #2: 1971
soundnav is an unknown quantity at this point
Default Early Sportster Shock Absorber Disassembly
Anybody know how to disassemble the early Sportster shock absorbers? 1957-64? I can't figure it out.
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to behold
I'm not familiar with that generation but I've disassembled lots of other shocks. You'll need something to safely compress the spring and there should be a collet of some kind at the top that locks the top retainer into place. Or, the top mount may be threaded onto the shock shaft. Regardless, the spring needs to be compressed before anything else happens. You can buy motorcycle spring compressors from MotionPro, Progressive or other vendors. Be careful, those springs have lots of tension on them!
Eric
Magneto Sportster's Avatar
Magneto Sportster Magneto Sportster is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1959
Magneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond repute
You will need two things:
1.) Factory Service Manual
2.) Shock compressor
The shocks need to be compressed, then the bottom eye rotated 90 degrees, then the compressor slowly released. I can post photos of my shock compressor if you need to see it. It would be a bit dangerous to attempt it without a proper shock compressor.
"Ride 'em, don't hide 'em!"
i made my own compressor. photo uploader Magneto Sportster has the H-D factory version.
Old 11th August 2020
Heff's Avatar
Heff Heff is offline
Sportster/Buell Model: Xlh
Heff is a name known to allHeff is a name known to allHeff is a name known to allHeff is a name known to allHeff is a name known to allHeff is a name known to allHeff is a name known to allHeff is a name known to allHeff is a name known to allHeff is a name known to allHeff is a name known to all
Shovelhead clutch steels work as well. One on each end, all-thread to pull it all together.
I use a press. Just gotta make sure you have the top spring eye in there correctly. You're trying to compress the spring and spring cover...if you don't see the upper collars start to loosen up, something is in a bind. When youre doing it correctly, the collar will open up. Sometimes the fall out, sometimes you need to give them a little wiggle with a long screwdriver.
Caution is needed...but you're not taking apart a strut. Just pay attention to those collars, and watch them to see when they move.
72 xlch
Old 13th August 2020
Thanks for the responses. I will be back in the garage this evening and will try to disassemble shock again.
I now have a decent shock absorber compressor so I have the right tool for the job.
