0 Hard saddle bags -
Last Post: Samedward
Last Post: Cablejudge
Last Post: XL1275
Last Post: ReddTigger
0 "S" model specific Q&A
Last Post: ftwflh
Last Post: XL Dane
4 What will 10 cents buy?
Last Post: Iron Chuck
Last Post: DollarBil
Last Post: Proteus
Last Post: soundnav
0 Swapping out single speedo for 1200 dual gauge setup
0 HTML Code
0 AGM battery for 76' XLH
Last Post: The Doctor71
Last Post: sprink
PlanB, Cuco6924 (74), 1200sporty (63), iron68 (49), LifesHarlequin (36), mattosm (35)
Old 19th June 2020
NGOT8R NGOT8R is offline
Sportster/Buell Year: 2019
NGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud of
Default What’s your fuel injected 1275 idle speed?
To members with 1275 fuel injected engines; what idle speed are you running? My PV is showing a set idle speed of 1118. Should this be slightly higher with Impact .560 cams or is this perfect? Thanks
Old 19th June 2020
hexnut's Avatar
hexnut hexnut is offline
Sportster/Buell Year: 2014
Its programmed in the computer. You can change it with a power vision. But that's perfect. I think my is 1050.
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
Old 19th June 2020
Thanks hexnut. I wasn’t sure if I needed to raise it or not. I’ll leave it at 1118.
Old 19th June 2020
Mines set at 1,000 rpm when up to temp. It's 1,300 rpm after a cold start and then drops down. Idle MAP is 40 KPa when up to temp.
Old 13th August 2020
60Gunner's Avatar
60Gunner 60Gunner is offline
That's because of your tune to run best at 1600 rpm and your whacked out timing table. Both my sporty and now my tc 103" idle at 33 - 34kpa
and your elevation isn't much different.
In fact most people I know are low to mid 30s and lower is better.
