0 My 08' Nightster
Last Post: FiftySixer
Last Post: rockrock513
Last Post: joes95bobber
0 Hard saddle bags -
Last Post: Samedward
Last Post: Cablejudge
Last Post: XL1275
0 "S" model specific Q&A
Last Post: ftwflh
Last Post: XL Dane
4 What will 10 cents buy?
Last Post: Iron Chuck
Last Post: DollarBil
Last Post: Proteus
Last Post: soundnav
0 Swapping out single speedo for 1200 dual gauge setup
0 HTML Code
0 AGM battery for 76' XLH
Last Post: The Doctor71
PlanB, Cuco6924 (74), 1200sporty (63), iron68 (49), LifesHarlequin (36), mattosm (35)
  #51
Old 25th July 2012
Stick_Man's Avatar
Stick_Man Stick_Man is offline
Sportster/Buell Model: 1981 IronHead
Other Motorcycle Model: 1975 Aermacchi/H-D SX 175
Stick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura aboutStick_Man has a spectacular aura about
Originally Posted by mikethebike61 View Post
Riding is the final test but you check end play by attempting to move the arm side to side and testing preload by moving cup and down. Any side to side is bad and binding up and down is bad. FSM tells you everything to look for.
should it move up and down on its own?
I can move it up and down but with some force otherwise it'll just sit there
I guess I can back off the pivot bolt a little
Old 13th August 2020
rocketnorton's Avatar
Sportster/Buell Year: 1970
Other Motorcycle Year: 80+
rocketnorton is a splendid one to beholdrocketnorton is a splendid one to beholdrocketnorton is a splendid one to beholdrocketnorton is a splendid one to beholdrocketnorton is a splendid one to beholdrocketnorton is a splendid one to beholdrocketnorton is a splendid one to beholdrocketnorton is a splendid one to beholdrocketnorton is a splendid one to beholdrocketnorton is a splendid one to beholdrocketnorton is a splendid one to behold
anyone know wrench/socket size on rh locknut?
hard to get measurement on bike [70xlch] w/o takin bunch of stuff off.
been lookin for 2 days on the netz.
tia.
pete
Master Bike Builder
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
1 3/8” hex nut on right.
Master Bike Builder
7/8” for the hex on the pivot bolt.
The bolt fixes the bearings to the frame.
The big nut sets the preload.
Old 14th August 2020
thx
was preload nut i needed.
