0 My 08' Nightster
Last Post: FiftySixer
Last Post: rockrock513
Last Post: joes95bobber
0 Hard saddle bags -
Last Post: Samedward
Last Post: Cablejudge
Last Post: XL1275
0 "S" model specific Q&A
Last Post: ftwflh
Last Post: XL Dane
4 What will 10 cents buy?
Last Post: Iron Chuck
Last Post: DollarBil
Last Post: Proteus
Last Post: soundnav
0 Swapping out single speedo for 1200 dual gauge setup
0 HTML Code
0 AGM battery for 76' XLH
Last Post: The Doctor71
PlanB, Cuco6924 (74), 1200sporty (63), iron68 (49), LifesHarlequin (36), mattosm (35)
Old 13th August 2020
heathkeenan heathkeenan is offline
Sportster/Buell Year: 1970
heathkeenan is an unknown quantity at this point
Unhappy 1970 XLCH Project Not starting
Hey guys, I need help. I put this bike together as a project bike and now I can't get it to start. When I turn the petcock on fuel comes out of the overflow hole every time. I've tested the float, it floats. I've set the float to 3/16" drill bit as required, still leaks. I've taken the cup off to see if the jet turns off the gas when the float is up and it does. Put it all back together, it leaks. I have verified that when I turn the throttle there is gas in the carb.
I've also tried to spray starter fluid in the carb, bike won't turn over. I have verified a spark at both spark plugs. I have adjusted the valves, verified the timing at the cams where all the marks line up.
If anyone lives near Palmdale, CA I could use some help!!
Otherwise, any suggestions would be really appreciated.
Thank you!!
Tipofthelake Tipofthelake is offline
Sportster/Buell Model: XLS 1000
Sportster/Buell Year: 1979
Sportster/Buell Year #2: 1973
Other Motorcycle Model: Electraglide
Other Motorcycle Year: 2007
Tipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to allTipofthelake is a name known to all
What carburetor? Points or electronic ignition?
If the gas is still overflowing then something is up with the float, the valve, or both. You could try rocking the bike quickly side to side after turning on the petcock to see if it just needs a little help getting moving, but I would say reduce the height setting a bit if that doesn't help.
What is your kicking procedure? I turn on the petcock, full choke, no ignition, hold the throttle wide open and give 2 good prime kicks, 3 if one isn't up to snuff. Then half choke, find tdc, ignition on, and kick it like it owes you money. If you're not sure the idle is set high enough (which will make kicking a bear) just take the slack out of the throttle by twisting it, then give it a tiny bit more before kicking. Just don't keep moving the throttle though or you'll flood it. If you flood it you've got to let off the throttle, choke off, and kick it 3-4 times to clear it and start over.
Also, with a freshly rebuilt and empty (to start) carb you might consider giving a few extra prime kicks when you first start.
Ok, I'm guessing after glancing through the manual that you've got a bendix. If the rebuild kits are anything like the keihin kits the float valve may be an issue, and may have a spring loaded nub on top of it that can make setting the float a pain. If you still have the old one and it is passable try putting it back in instead. If not try holding the carb so that the float is hanging down closer to vertically rather than flat on the bench when setting it so that the valve just seats.
Old 14th August 2020
Default 1970 Sportster that won't start
Thank you sir!! I will try this tomorrow morning and let you know.
I'm sure I have the spring right but di you have any pictures you can share that could help?
Thanks again!!
I'm afraid not as I am only vaguely familiar with that carb. I will say that you should post this question in the ironhead subforum as that is where the people who have the experience to help you are usually active. Good luck.
