0 cancer
3 Ironhead Pictures Thread
Last Post: Blowupster
Last Post: eddie XLX
0 Not shifting out of 1st gear or Neutral
Last Post: webman94
Last Post: jharback
0 Metal Polishing
Last Post: ed_in_az
0 Rigid Mount Fork Info
0 Royal Enfield 650 Twin: $5799, 47HP, ABS
Last Post: farmall
0 Moto Guzzi V9 Bobber debut
Last Post: farmall
Last Post: Magneto Sportster
0 When Were You Born?
Last Post: MacSporty02
0 BMW R 1200 GS clutch replacement
Last Post: farmall
0 Mid controls on a Custom
Last Post: SportstrKurt
Last Post: Curvemadd3
0 This Mikuni vm38-9 is driving me insane
Last Post: DirtyHarry68
0 Cam cover
Last Post: Pezed
0 easy seat fix for 2004-2006 1200c
Last Post: chain
0 Installing Brembo Goldline brakes on a 1998 XLH1200
Last Post: Randy_rots
0 Anybody Collect Dealer Logo'd Harley T-Shirts?
Last Post: BWP 5p
0 Led upgrade 1200S
Last Post: NZstu
0 seat bolt
0 where is that air shock thread?
Last Post: robbie202
Old 26th September 2018
Chuckthebeatertruck's Avatar
Chuckthebeatertruck Chuckthebeatertruck is offline
Sportster/Buell Model: Xlh
Sportster/Buell Year: 1959
Sportster/Buell Year #2: 1969
Other Motorcycle Year: 1969
Originally Posted by spuggy View Post
However, did hit an unexpected snag.
The ally body of the bulb won't go into the RH55 bulb holder. Won't go deep enough to locate the pins, because the ally ring is wider than a "real" glass bulb at that point.
Doesn't look to be fouling by much, could prolly get enough depth to engage the pins with a rough file and 2-3 mins shaping a bevel on that first knurled portion there - but it does definitely foul and won't go in.
Bizarre, that wasn't a problem on anything else I tried this bulb in...
That's likely because the LED was made to 1158 specs. One of the really crappy things about many LEDs is that they are actually 1158 mounts because their intended market are scooters in the countries where they are made (mostly Taiwan, China, and Thailand). Almost all those scooters are 6V . . . so it makes the most sense to do them up as 1158 bases. Then you swap the pin position and the resistor and next thing you know you've got 1157 bases that are just a bit more "thick" than they need to be.
LED bulbs are still very much the wild west of lighting when it comes to standardization -- both physical dimensions as well as lighting output and colour.
As for plate illumination; there are other ways to accomplish this with LEDs. Currently, there are at least four different makers of bright white plate mounting LEDs. I used these ones on a recent project:
https://www.ebay.com/itm/4Pack-White...QAAOSwF1tZbXAL
It lets you "experiment" with different configurations and even to separate your license illumination from the tail/stop circuit. This is more important for guys working on non-stock bikes with remote location plates.
Yochstein's Avatar
Yochstein Yochstein is offline
Sportster/Buell Model: XLH Sportster
Sportster/Buell Year: 1984
Yochstein is a name known to allYochstein is a name known to allYochstein is a name known to allYochstein is a name known to allYochstein is a name known to allYochstein is a name known to allYochstein is a name known to allYochstein is a name known to allYochstein is a name known to allYochstein is a name known to allYochstein is a name known to all
Originally Posted by Chuckthebeatertruck View Post
How often is this happening to you?
Bulbs don't fail regularly from vibration.
If you find you're replacing them more than every few seasons; you need to look more deeply as to why.
Voltage spikes, bad grounds, or poor mounting will cause issues -- but bulb filaments in these series are amazingly vibration resistant.
In other words, an LED won't necessarily "solve" your issue.
I noticed that my entire brake light assembly (bracket that bolts to the fender) is a tad loose. I was thinking that vibration had something to do with it. I have a brand new voltage regulator and new circuit breakers. I'm wondering if one of those are the culprit?
That's called an "intermitent ground (earth) fault." Your bulb didn't die because of vibration, it died due to a poor ground.
Fix it and carry on.
Old 27th September 2018
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
Do you recall which particular model bulb serves the dual function as both a red tail bulb and the white bulb to light up the license plate?...
This is the one...
1157 LED Bulb - Dual Function 25 LED Motorcycle Bulb
https://www.superbrightleds.com/more...-bulb/170/767/
Overview
LED replacement bulbs can fit motorcycle tail lights and brake lights while doubling as a license plate light. This 1157 dual-contact, dual-function bulb has 25 LEDs (3-mm and 5-mm). 19 Red LEDs aim forward from tail lights and brighten when brakes are engaged, and 6 radially mounted cool white LEDs illuminate your license plate. BAY15D 15-mm bayonet base for easy plug-and-play installation—just twist to lock in place. The energy-efficient bulb operates within a wide 9-14.8V DC range and is designed to last 50,000 hours on your motorcycle—42 times longer than incandescent bulbs
In Stock
$12.99 ea. (per Bulb)
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Yochstein's Avatar
Will do, thanks!
Yochstein's Avatar
This is the one...
Overview
In Stock
Thanks Mick. That's worth taking a shot. I need to fix my assembly and tighten everything up before putting another new bulb in there.
Old 29th September 2018
forqueue forqueue is offline
Sportster/Buell Year: 1976
forqueue has disabled reputation
A conventional 2357 is the same fit-footprint as an 1157.
Same parking light but the brake element is much brighter (40 vs 32 lumens).
Down-side is 2357 is rated for 1/3 operating life as a 1157
Tried many various LED bulb offerings over the years and none were bright enough.
Then heard about Osram-Sylvania ZEVO 2357R. Pricey @ $20 for 2- but....WOW.
Lifetime warranty. See youtube for comparisons.
They offer a lower priced 1- year version too, SYLVANIA 2357 RSL.
Old 30th September 2018
IronMick's Avatar
Originally Posted by forqueue View Post
... Tried many various LED bulb offerings over the years and none were bright enough...
Same here, until I found the LED bulbs from www.SuperBrightLEDs.com
sportsterdoc's Avatar
They have a great selection!
