Last Post: Diogenes415
0 Compensating sprocket.tighten and "pop!"
0 oil dripping fom carb
Last Post: maxedd
0 Primary cover screws... Washers??
Last Post: 72 Ironhead XLH
0 1979 1000xlh front drive (chain) sprocket tourque
0 Screamin Eagle heads
0 New to me timing mark
0 What's Wrong With My Bike
Last Post: PoodlePunche
0 Clutch Went Out Of Adjustment - Grenade Plate
0 why you can't be seen
0 What makes a Hugger a Hugger?
0 shifter shaft bent
0 time will tell, but...... (blacked out: fad?)
5 Are you married or single???
Last Post: AlexD
0 1200S Fork Slider Differences 1999 to 2000
0 Special tools
Last Post: thefrenchowl
0 Dealer says, "Sportsters are just a Phase"
Last Post: handa700
0 Harley Hacks & Tech Tips - Build It Better™ - So Much Useful Info!
0 Clutch spacing 1979 1000xlh
1911Bronco, Blackbird (84), thai808b (67), Nathan71 (53), lucky-13 (51), Barndog (49), discobanjo (45), albana (43), pat5150 (38)
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
ReddTigger is right. I would also wonder about the o-rings around the locating sleeves with head gaskets that don't need them. Another common issue.
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
If you have the same crappy paper base gaskets as my 1991, you might want to upgrade to the Cometic metal gaskets. When I did my 1250 upgrade, the rocker and base gaskets crumbled like Egyptian mummies. I was extra careful not to have a piece of King Tut fall into the crankcase.
I had some base gasket weeping for many years, practically since fairly new. Now, with the metal base gaskets, not the least sign of oil.
John
