27th June 2022
Posts: 125 Sportster/Buell Model: 1200 Low Sportster/Buell Year: 2006 Other Motorcycle Model: Kawasaki Vulcan 750 Other Motorcycle Year: 2002
Front wheel
How difficult is it to replace a 19" cast front wheel with a wire spoke 21" front wheel? Is it just a simple bolt on, or is there more involved? The fender was already designed for the 21" wheel.
27th June 2022
Posts: 7,004 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
If you keep the same bearing size is plug and play.
4 Weeks Ago
Does anyone have any information about axle and bearing types/sizes? Are the forks and brake caliper the same as models that came with a 21" front wheel? Will the brake disc from the 19" wheel bolt onto the 21" wheel? I am considering both used H-D wheels and aftermarket wheels.
4 Weeks Ago
Posts: 9,422 Sportster/Buell Model: Sportster 883►1200 Sportster/Buell Year: 1994
4 Weeks Ago
Posts: 420 Sportster/Buell Model: XL1200R Roadster Sportster/Buell Year: 2008 Other Motorcycle Model: Norton 850 Commando Other Motorcycle Year: 1973
Being that your bike is an 06 a wheel from 2000-2007 should work IIRC. (HD changed wheel bearing size and/or type in 2000 and 2008)...but double check all that at
https://partsfinder.onlinemicrofiche....asp?make=hdmc
a great resource for researching parts swaps/compatibility, used it myself for a (successful) wheel swap
